Old 07-12-2023, 05:38 PM   #1
cgster
Installing bed without floor
Trying to put my truck together instead of having parts/panels everywhere. I don't have the wood flooring yet for my truck. Will the bed sides/panels still mount to the frame ok without any bed wood being installed? I've never pieced a bed together, so not sure.
cgster is offline   Reply With Quote
Old 07-12-2023, 05:50 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Installing bed without floor
Wouldn’t be a problem . The bed will sit 3/4 of an inch lower without the wood .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-12-2023, 05:53 PM   #3
cgster
Good, thanks!
Old 07-12-2023, 08:40 PM   #4
CC69Rat
CC69Rat's Avatar
I usually cut small scrap pieces of either the old bed wood, or something the same thickness, cutoff of your new bedwood or something.
Drill the hole for the bolt in the bedside, slip it on top of the cross sill where it would be positioned and kinda give yourself a spacer temporarily
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-13-2023, 01:24 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
You could put a 4 x 8' sheet of 3/4 plywood down, so you'd have a workable bed surface, until your planking goes in.
Old 07-13-2023, 08:42 AM   #6
72c20customcamper
Longbed a 4x8 will be one inch short . All my wood is cut to 97” lengths but for a temp solution it would work
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 07-13-2023, 12:11 PM   #7
67C10Step
67C10Step's Avatar
Here is what I did for a mock up.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-14-2023, 01:16 AM   #8
'68OrangeSunshine
I have a shortbed, so I cut off 20-something inches. Also a gap on one side of about 1-1/2'' that I shape a 1 x 3 to fill. When the plywood's peeling layers, or soaked in black oil, or warping, I just get a fresh sheet.
An oak-planked back deck is beautiful, but I'd have to keep a sheet of plywood on top if I still used it as a Truck. Which I do. If I wanted a show car, I buy a Dusenberg or Maserati.
