Old 07-14-2023, 05:36 PM   #1
Lucasd2002
source to tap into interior dash lights - aux switches
I'm adding some auxiliary switches to my truck and the new switches have connections for the dash light circuit so they can illuminate at night or whenever the headlights are on.
I was planning to add a posi-tap onto a source wire behind the dash.
Is there a typical source that people use for this? Instruments? My vintage air HVAC? Does it matter where I tap in?
Thanks in advance
truck is a 1988 GMC crew cab v3500.
Lucasd2002 is offline   Reply With Quote
Old 07-14-2023, 10:13 PM   #2
HOTFUN
HOTFUN's Avatar
Re: source to tap into interior dash lights - aux switches
Most of the GM trucks it is a solid gray wire for the dimmable dash lighting cluster circuit under dash. T tap that gray wire for the power to your lamp.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 07-15-2023, 03:20 PM   #3
Lucasd2002
Thanks man!
Old 07-19-2023, 09:38 AM   #4
MalibuSSwagon
There is actually a tap on the fuseblock, for 81+ anyways, for the interior dash lamps. It's the slot labeled D "LPS" on the diagram. Diagrams from my 86 factory manual
MalibuSSwagon is offline   Reply With Quote
Old 07-19-2023, 12:53 PM   #5
406 Q-ship
406 Q-ship's Avatar
Look at the fuse block for a blade connector right next to the instrument lamp fuse (usually the short fuse on glass fuses). That tap will be marked for instrument lamps, use that for you add on gauges.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 07-20-2023, 05:04 PM   #6
Lucasd2002
Thanks for all the responses guys!
Running a line from the fuse box would be ideal and simplify everything.
After looking for the correct connector to tap into the "LPS" port of the fuse box... I'm a little confused.
I found the following info here on this site.
NW-784800 for the non-piggyback "BAT" connector.
NW-784801 for the piggyback "BAT" connector.
NW-784802 for the non-piggyback "IGN" connector.
NW-784803 for the piggyback "IGN" connector.
Is there one for the "LPS" port? Will this one work?
Should I just use a standard spade connector?
edit: this kit looks like it might be relevant
Old 07-21-2023, 08:04 AM   #7
MalibuSSwagon
I've always used spade connectors or pigtails I clipped out of junkyard trucks. But that Summit link looks legit, think I'm going to have to order it and see if that works! Trying to make everything legit now and I always knock out the spade connector for my OBD2/Check Engine light when I'm under the dash.
