Old 03-30-2002, 09:29 PM   #1
Custom 68
Custom 68's Avatar
Post o.k tell me about starters
I think I am in need of a new starter. Mines has gotten hot because of the headers I even replaced the Solenoid a couple of times until I installed a "remote" one. Anyway what do you know about the small hi-torque ones. Are they worth the money? I am going to get the battery checked but mine is really hard to start. The starter is 12 years or so old.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-30-2002, 09:32 PM   #2
Super Chevy
Super Chevy's Avatar
Post
yea,for the price of a starter i would buy one if your getting stuck because it wont start,my friend has one of those mini ones,good quality and turnes over pretty fast,and when you buy a new starter a heat shield is worth the time to put it on, (i think they are like $10? )
www.superchevy.cjb.net
1972 Custom Deluxe/10
mild 350: Hedmen headers and dual 3" exhaust ,harlin sharp roller rockers ,MSD ingnition ,Mallory dual point K&N 14x4 air cleaner ,Holley 600 4bbl ,Edelbrok Proformer intake
TH350 with lock up verter and 1600 stall
American Racing 15x8.5 and michelan 28x8.55
CHEVY makes HORSEpower,while ford makes ponypower
Bowtie or nothing!
Super Chevy is offline   Reply With Quote
Old 03-30-2002, 10:04 PM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Post
I was having the same trouble even with a remote solenoid,my headers were very close to the starter, I now use a GM Delco Remy high torque mini starter, it's a great little starter,80% more torque than a standard GM high torque unit, draws less amps and only weighs 8 pounds, heres a pic to show just how small it is.
72 Blazer CST, 2-1/2" skyjacker lift with 33x12.50 bfg's
71 Cheyenne K-20,4" tuff country lift with 36's.
69 Custom 30 long stepside 4" rancho lift 36" directional tires,14 bolt rear with detroit locker,dana 60 front with trac-loc
1987 k-5 blazer
2001 Intrepid
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-30-2002, 10:18 PM   #4
Chevyman69
Vortec 350's Suck
Post
I have the same starter as Blazerman on my 69, while my motor has not been started, it fits excellent, quite a ways from my headers, cause its so small. And it turns over my motor with ease and spins it pretty fast, has a 11 tooth gear instead of stnadard Chevy 9, but bolts up to any 168 tooth flexplate or flywheel, I think it was worth it.
69 CST 10, 402, steel crank, heavy rods, Federal Mogul Forged Pistons, 9.9:1 compression, polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Rochester QJET, MSD HEI, MSD 8MM Wires, Dynomax Ceramic coated headers, should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Auburn Pro Series Posi, buckets/console air/tilt/tach 4wheel discs
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, loaded, 350 Accel filter/cap/rotor/coil/AC Delco wires/AC Delco RapidFire plugs, Edelbrock intake and headers, 180 degree thermostat, Hypertech Thermomaster Chip, true duals 700R4 with B@M Shift Kit for now!
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 03-30-2002, 10:54 PM   #5
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Post
that have the nts for the ol' 454 in my truck?
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-01-2002, 09:45 AM   #6
Custom 68
Custom 68's Avatar
Post
Thanks guys I will do some checking sounds like those who have used them like them!
Thanks again
Dave
Dave
Old 04-01-2002, 09:49 AM   #7
REPO1
Shortbox wanna-be.
REPO1's Avatar
Talking
These are great items. Highly recommended.
Why do you think GM uses them on new vehicles now?
Actually, come to think of it, if you are in a pinch, check the wrecking yards. I know my '97 Z28 has a nice small one on it. And it will bolt right up.
Reid
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 04-01-2002, 01:53 PM   #8
busterwivell
Post
I was burning up a starter every six months on my 402. switched to a mini starter and haven't had a problem since. Try it, you'll like it!
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
