07-16-2023, 03:27 PM | #1 |
Combo valves backinaday
Didn't want to derail the conversation in another thread, so I thought I'd throw this out for discussion, ICAC:
So, were the OEM combo valves from '71 onward actually application specific? Seems to me that GM being GM, they would have used a generic product and bought them by the freight car |
07-16-2023, 04:30 PM | #2 |
Re: Combo valves backinaday
I think they were application specific. Member Keith Seymore has shown us the actual engineering charts for these trucks on a couple of threads, such as this one:
https://67-72chevytrucks.com/vboard/....php?p=8909230 As you can see in the charts, depending on the model of truck there are different specs for the proportioning valve. Last edited by dmjlambert; 07-16-2023 at 04:30 PM. Reason: corrected link |
07-16-2023, 04:36 PM | #3 |
I suppose they could have screwed in the appropriate proportioning valve onto the back of a generic combination valve, and the metering and shuttle valves are all the same.
07-17-2023, 02:20 AM | #4 | |
So, in '71, all metering valves were 138#, with prop valves at 300# or 470# but in '72 all metering valves were at 75# and all prop valves at 300# To slither further down the rabbithole, I wonder what values passenger cars used, and what values the now ubiquitous PV2/PV4 parts use. |
07-17-2023, 02:23 AM | #5 |
Sure, the components just screw in, and in turn the components prolly use standard housing+valve but different springs, BUT from GM's perspective the combo valves came with different part numbers spec'd from multiple vendors
