Old 07-17-2023, 01:47 PM   #1
OregonNed
OregonNed's Avatar
Red face Drop Springs - '68 C10
Thought I would ask this question here.
Scenario - my '68 C10, trailing arm and coil rear suspension.
Had a 4/5 drop done recently - in the rear, a combination of 2" blocks and 3" CPP lowering springs. Been driven 150 miles or more so far, so I would assume any settling in is done. Work was done locally. The driver side from ground to top of the wheel arch has about one inch more height than the passenger side.
Not knowing much about springs personally, does the way they are installed have anything to do with this? Can rears be installed differently, or rotated to make the sides match? I know the fronts seat into pockets on the lower control arm. Posed this question a few places. I notice on the summit site the specs shows this spring lowers in a range, so wasn't sure if that meant they can be seated different ways. Thanks in advance, appreciate your patience with my lack of knowledge...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 07-18-2023, 03:27 PM   #2
CC69Rat
CC69Rat's Avatar
Re: Drop Springs - '68 C10
Is the front level? You might be experiencing what's commonly referred to as 'Chevy Lean'.
I can explain - bit my first question would be more focused on the front. See if it's lower on the drivers side.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-19-2023, 04:05 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Try swapping the springs left to right, while doing so make sure they're both clocked correctly in the plates. Check the frame and bed, these beds have taken unimaginable beatings over the years. Level the axle and start inspecting taking measurements of the cross sills and frame mounts...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-19-2023, 12:04 PM   #4
OregonNed
OregonNed's Avatar
Thanks both for the advice - getting it in the shop in a week or two and will look into this. will post back with results/fix
Old 08-14-2023, 12:55 PM   #5
OregonNed
OregonNed's Avatar
Wanted to give an update on what we found. My driver front lowering spring was not seated properly in the top control arm, and simply rotating it into the pocket on the bottom and seating the top was the issue. Basically it was "high centered" on the stamped section at the top making up the 1" difference. We didn't initially see this, so when we got it on the lift again was able to determine this. Once corrected, the back is now also perfectly leveled. Seems just the one corner threw everything out of whack.
Old 08-14-2023, 10:52 PM   #6
HO455
Post Whore
HO455's Avatar
Good to hear you solved the problem. And thanks for the follow up post. We all learned something.
RIP Bob Parks.
Old 08-15-2023, 10:47 AM   #7
dagnabbitt
dagnabbitt's Avatar
I'm curious, do you think it would have eventually slid into place, or was the adjustment completely necessary, ie, it would have had the lean until you did something about it.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-15-2023, 11:58 AM   #8
OregonNed
OregonNed's Avatar
It definitely wouldn't have went in on its own, so moving it into position was pretty easy separating the lower ball joint, and removing the swap bar clamp on that arm and the shock too... Its just perfect now on all corners and couldn't be happier. The drop is exactly how I wanted it..
