Distributor installed wrong ?
I just noticed the distributor in the used motor I bought has the vacuum advance pointed towards cylinder # 3 on the driver side . Every SBC Ive seen has the advance pointed to cylinder # 6 on the passenger side . Is the distributor installed incorrectly ? I watched a video of it running as is very well .
Re: Distributor installed wrong ?
It doesn't matter which way it points, the only thing that makes it point to #6 is clearance of items like fire wall, carb, wires ect ect! BTW I always point it toward #6ish! You would just have to relocate the plug wires!
Take Care Troy |
Proper orientation for clearance in relationship to manifold.
71 C-20 07 Magnum RT AWD |
Please rotate I don’t know how..
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jan 2001
If you're putting it in a 4WD you might have a problem with the coil connector running into the firewall.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Having the vacuum advance pointing at the #6 cylinder provides you the ability to twist the distributor fully for proper timing. I would pull it out and reorient it. GM did a pretty decent job engineering that ignition system…
It will most likely function just fine like that but my OCD would kick in every time I opened the hood. I'd pull it and orient it like you'd expect.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
