![]() Join Date: Nov 2001
Question about thermostat housing
How perfectly flat should the surface be and how much pitting is too much pitting. From what I can read off the numbers,
GM • 3877660 . Any venders on here with new replacement? Also is it possible to mill down some, just a thought. Ill never forget what my high school cooking teacher said back in the days, when in doubt throw it out lol. Thanks NGN Nick |
Who Changed This?
![]() Join Date: Jan 2013
Re: Question about thermostat housing
If you have a piece of wet-or-dry sandpaper, you can dress it back to no pits. Alternatively, you can use #1 Permatex to seal it. Just know that it'll be tough to get off later. I had a '75 Dodge that I put a timing set in way back when. No new timing cover gasket, just that #1 Permatex. Didn't leak a bit.
I have installed/R&R very nasty looking housings in the past using both gasket and silicone. None leaked. They don't like to come apart afterwards though. My current setup uses an oring type seal that I could not get to seal...always leaking/weeping. I removed the oring and used regular gasket with success...go figure. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Jan 2001
Sandpaper (face-up) on a flat surface. Round and round and back and forth. Good as new.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Apr 2016
If after that yours doesn't turn out good as new, or to answer your question about vendors here, I bought one of these from specialtyretail http://67-72chevytrucks.com/vboard/s...d.php?t=838785
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Sep 2014
If you want to keep the original I have filled pits in housings on my Studebakers with JB Weld . Clean the housing well with brake clean or lacquer thinner fill and sand with fine paper as mentioned prior . This way just a coat of Indian head gasket shellac and your good to go
