Old 01-09-2004, 12:42 AM   #1
ScottH
ScottH's Avatar
Panhard bar differences
Can anyone tell me the difference between the panhard bar from a 1/2 vs 3/4? Will one from a 3/4 fit a 1/2 truck? Any differences in bolts sizes, etc.?
Any info is appreciated.
Thanks!
ScottH is offline   Reply With Quote
Old 01-09-2004, 03:33 AM   #2
WB72
Before and After
WB72's Avatar
Both the length and the diameter are larger on the 3/4 ton.
I just picked one up from a wrecker today. it looks like there is close to 10" -12" difference.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-09-2004, 03:47 AM   #3
Sweet72
Sweet72's Avatar
bushings are different size also.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
