Old 07-31-2023, 10:07 AM   #1
blazer2007
screen for rear slider window.anyone done it ?
I was thinking of a way to make a screen for the rear slider on my 80,s. Anyone make one. I thought the windows lift out but they don,t as I was going to make one that would lift into the slots on the window channel ,but it doesn,t do that.
blazer2007 is offline   Reply With Quote
Old 08-01-2023, 09:07 AM   #2
rick1956
rick1956's Avatar
Re: screen for rear slider window.anyone done it ?
A little buggy up there, is it?
Interesting notion... I'll have to keep an eye on this one to see what transpires. I would think you'd have to use some sort of glue-on, external design. It would also have to be minimal in stature as to not appear as if you glued a wooden portrait frame onto your window.
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 08-01-2023, 10:00 AM   #3
blazer2007
I was hoping it would fit like a sliding window in your house, push up in the track and then put it in the bottom track but no . The truck doesn,t do that. I was thinking yesterday maybe some sorta Velcro. No bugs but anything in the box comes in the back window and it is hot here.
Old 08-05-2023, 04:32 PM   #4
kglowacky
maybe a thin frame that you add thin strip magnetic tape to that just sticks on the oem window frame.
kglowacky is offline   Reply With Quote
Old 08-06-2023, 09:07 AM   #5
Pontiac1976
Pontiac1976's Avatar
I would use this https://www.amazon.ca/Fastener-Adhes...1zcF9hdGY&th=1 put the wiry side on the glass/alum frame side that does not move make sure to clean and dry in stall on a warm day. Get your screen of your choice sew the meshy side to the screen make two seams stretch tight press in to place. I all was put the wiry side on 1-2 day let it sit first before putting screen side on make sure you put the screen on a cooler day in the shade help is a blessing make sure you get it right some time it will pull wiry off the alum frame/Glass. with a little heat on hot day, it can be pulled off with a little work clean easy without a lot of work and you would never know it was on thereafter. I hope this help you.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-06-2023, 09:07 AM   #6
mongocanfly
Post Whore
mongocanfly's Avatar
I don't remember how it was,this was in the 80s, but Dads dodge truck with the rear slider had a sliding screen on it..you could also have it open or closed..I think it was fastened to the slider window
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-06-2023, 09:14 AM   #7
Pontiac1976
Oh the black screen not alum work better look nicer.
Old 08-07-2023, 10:26 AM   #8
blazer2007
I was thinking of the velcro type method. something I could roll up and stick in the glove box when not in use and just have 4 little tabs on the sliders. I think that will work.
Old 08-08-2023, 10:34 AM   #9
blazer2007
Well looks like I was over thinking this project. I was at the hardware store looking at screen and beside the the screen is all the plastic do-dads to make your own custom screens. Make a screen paint it ,and a little Velcro and done.
