Old 07-31-2023, 01:08 PM   #1
Toro
Toro's Avatar
Dana 44 front spindle/wheel bearings part #'s
I found these parts numbers from a few other threads for front wheel bearings:
Timken set 37 front inner
Timken 442380 inner seal
Timken set 45 front outer
I'm trying to find the part numbers for the seals on the spindle, there's an inner that slides right onto the shaft, and then outer that sits behind caliper bracket/dust shield. Hope that description made sense. And hope those wheel bearing #'s are good too. Anyone familiar with these? Thanks so much.
Toro is offline   Reply With Quote
Old 07-31-2023, 01:24 PM   #2
MJN
MJN's Avatar
Re: Dana 44 front spindle/wheel bearings part #'s
Are you asking for the spindle bearing kit seals? https://www.rockauto.com/en/moreinfo...268759&jsn=271
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-31-2023, 08:40 PM   #3
Toro
Toro's Avatar
Yes, I believe that's it. I think my bearing is okay, was looking for seals.. part numbers are there. Was looking on RockAuto, not sure how I missed it. Thanks.
