Old 08-06-2023, 10:05 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
4 row radiator.
Looking for a 4 row radiator without the plastic tanks. Who would you recommend? Thanks.
desert-rat is offline   Reply With Quote
Old 08-06-2023, 11:02 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 4 row radiator.
I bought one a dog's age ago from O'Reillys before they changed their name- Kragen? Maybe they don't sell those anymore?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-06-2023, 11:03 PM   #3
dmjlambert
dmjlambert's Avatar
Re: 4 row radiator.
I removed mine and replaced it with a 2 row all-welded and lifetime warranty aluminum one, because the radiator shop that worked on the 4-row one said it was fine for now but it is marginally good. I sold the 4-row one here on the forum. I believe people re-core them. It was going to be about $500 for me to have it re-cored, but I know some people here on the forum re-core their own. So it costs money. At the time I didn't have the budget to do that and didn't have the desire to store it, so I sold it. Up until a couple years ago there were copper/brass radiators remaining in various stores, such as Outback Truck Parts. But now I think they're gone. There has been a couple-year-long void where they were unavailable. Now some manufacturers (or at least one) are starting to make new ones. Here is an example: https://www.oerparts.com/product/crd1634a.html
I can't say I recommend them because I haven't used one of theirs, but it looks nice. The 2-row aluminum one is equivalent to the brass/copper 4-row.
dmjlambert is offline   Reply With Quote
Old 08-06-2023, 11:43 PM   #4
PbFut
Re: 4 row radiator.
Champion has a decent 4 row. I also added their fan kit but now feel that was a mistake. A good factory schroud and fan set up is much more reliable and way less stress on our 50 yr old electrical system. Their radiator is very good.
PbFut is offline   Reply With Quote
Old 08-07-2023, 12:13 AM   #5
desert-rat
Re: 4 row radiator.
Is a 4 row really necessary though? I pulled a 4 row today and it's rusted inside. I'm putting in a rebuilt 350 with edelbrock top end kit. Only the block and the crank is being reused. If a 2 row is sufficient enough, I'll go that way.
Old 08-07-2023, 12:57 AM   #6
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Re: 4 row radiator.
Last month I installed this radiator after reading great reviews on the board. It's a 3 core, Champion says it will cool a 600-800 HP engine. I have driven 300 +mile with the a/c running the past month in 100+ degree weather on highway and city traffic and never went over 190 degree's. I'm running the stock clutch fan and shroud.
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 08-07-2023, 08:48 AM   #7
mr.mud1
mr.mud1's Avatar
Re: 4 row radiator.
hi,i can't advise on what's required in your area,i do build my own rads here,buying new brass/copper style cores from Spectra-Premium.i do know my 72 big block,A/C,Cheyenne Super truck built in the Fremont,California plant and for the first 25 years of it's life,hauled a camper back and forth to Idaho,had and was built with a 3 row rad.i re-cored it cause some dummy dropped it and pierced the core(dummy was me)I could've used a 4 row core but i figured a 3 row worked,no need to re-invent the wheel.the tanks for the 3 row with accept a 4 row core.
mr.mud1 is offline   Reply With Quote
Old 08-07-2023, 09:20 AM   #8
Jason Banks
Jason Banks's Avatar
Re: 4 row radiator.
Those 2 row aluminum radiators are usually just at thick and probably more efficient than traditional 4 row. Instead of having 4 rows that are 1/2 wide each they 2 row aluminum are usually 1 inch wide each...
Jason Banks is offline   Reply With Quote
Old 08-07-2023, 10:36 AM   #9
PbFut
Re: 4 row radiator.
I do not know which is more efficient, 2, 3 or 4 row. Seems logical that the higher number would be, given the factory used 4 on their bigger engines. In the recent 100+ heat the Champion 4 row/Spal system runs at acceptable temps with the AC on but it is clear that if I were towing I would probably have issues. With AC off, things stay well in control. I am looking into oil coolers, tranny and engine, to give me that extra heat sink needed to have no worries no matter the use, road grade, and air temp.
Old 08-07-2023, 11:44 AM   #10
CastIron
CastIron's Avatar
Re: 4 row radiator.
I've been looking into radiators recently and have been considering a few different aluminum models.
This is the model I'm leaning towards:
https://www.championradiators.com/Am...roud-1967-1972
It's made in China, but a bargain for a 2 row with 1" tubes. I'm not 100% sure (maybe somebody can answer this) but I think it fits in the mounts for the 2 and 3 row original radiators.
I've also considered this one (mainly because the tanks look more original), but it does require the 4 row mounts and shroud:
https://speedcooling.com/product/196...inum_radiator/
If you want an original style 4 row, Summit does sell this one:
https://www.summitracing.com/parts/sum-382006
CastIron is offline   Reply With Quote
Old 08-07-2023, 04:28 PM   #11
LS short box
Re: 4 row radiator.
On my 68 C10 LS swap I used an Afco aluminum. It was a generic LS. You can get them in standard SBC inlet and outlet. I think I got it from Speedway Motors. See pic.
LS short box is offline   Reply With Quote
Old 08-07-2023, 08:37 PM   #12
body bolt
Re: 4 row radiator.
I replaced my failed original 4 core with this with the intent of getting the original repaired. So far it has performed very well with A/C and +100F temps which is a good thing as the local shops that did repairs have disappeared.
body bolt is offline   Reply With Quote
Old 08-08-2023, 07:21 AM   #13
MARKDTN
Re: 4 row radiator.
If you are dead set against plastic tanks or all aluminum then I would find a local shop and have them use your tanks with a new core.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-08-2023, 11:58 AM   #14
72c20customcamper
72c20customcamper's Avatar
Re: 4 row radiator.
The reason factory rads a 4 row is the copper is a soft metal and doesn’t hold up if the tubes are wider . Aluminum tubes can be much larger I have a two row that has 1 1/2 inch tubes . Engine oil coolers are a good idea as the oil can carry away a lot of heat from the engine .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-08-2023, 07:58 PM   #15
weq92f
weq92f's Avatar
Re: 4 row radiator.
Indeed, I too purchased the CC369 w/the dual (generic) 14" fan and aluminum shroud (each fan rated at 1200CFM). Ended up not using the radiator, but instead mounting the shroud and fans on my original 4-core rad. While it did work and move air pretty good, it wasn't adequate with A/C on as at idle in summer, the temp just creeped up with both fans engaged.
I'm in the process now of an A/C update and purchased an equivalent set of spal 1850CFM fans. Those generics are now wall art.
BTW, the fans that Leadfoot racing ( champion's reseller ), the ones I bought from them, sell Online for 40 bucks each. The new spals were 180 each.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
