08-10-2023, 08:43 AM | #1 |
Alignment Specs?
Can anyone provide front end alignment specs ?
08-10-2023, 12:43 PM | #2 |
Re: Alignment Specs?
I got these specs from another site, do they seem right, any opinions?
Suggested Alignment Specs: CAMBER minus .5 degrees CASTER +3.0 to +5.0 degrees TOE IN 1/16" to 1/8" TOE IN |
08-11-2023, 11:29 AM | #3 | |
I target NEG .5 Camber & tell them to dial in as much Caster as they can w/that Camber set-point as the priority.
