Old 08-14-2023, 04:35 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Where do the heater hoses connect to?
It's an AC cab. No heat or AC connected yet. Where do the heater hoses connect to on both ends? Pics would help. I'll deal with the AC later. And not sure why the pic uploaded sideways. Thanks again.
desert-rat is offline   Reply With Quote
Old 08-14-2023, 04:58 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Where do the heater hoses connect to?
Flip for ya
3/4 goes to the water pump. 5/8 goes to the intake.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-14-2023, 07:31 PM   #3
Sheepdip
Sheepdip's Avatar
You might want to test your existing heater core with just plain water before putting any coolant into the system. There is usually a reason your heater core has been disconnected
Sheepdip is offline   Reply With Quote
Old 08-15-2023, 02:31 AM   #4
desert-rat
The PO said the heater core was leaking. But he gave me a heater core for a non ac cab. I'll just buy the correct one.
Old 08-15-2023, 02:32 AM   #5
desert-rat
Originally Posted by Getter-Done View Post
Flip for ya
Attachment 2287161
Thanks. Seems simple enough.
Old 08-15-2023, 09:51 PM   #6
Rust_never_sleeps
Rust_never_sleeps's Avatar
can always just pipe them together in the meantime.
You won't be wanting any heat for another few months ;-)
Rust_never_sleeps is offline   Reply With Quote
Old 08-15-2023, 09:56 PM   #7
Getter-Done
That is For Sure.
84 Chevy K-20
Old 08-15-2023, 10:01 PM   #8
Getter-Done
Just a suggestion.
Look at your fittings on the Water pump and intake.
They will tell the story.
Some Square bodies had a connection on the radiator.
A lot changes over the years.
84 Chevy K-20
Old 08-16-2023, 08:21 AM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A prior search found this:
Automatic and A/C trucks returned to the radiator for better overall cooling and base trucks returned to the pump for quicker warmup.
On my A/C truck, the top hose (outlet from heater core) is routed to the radiator.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-16-2023, 10:46 AM   #10
PbFut
What year? I don't know about early years but my 72 AC truck has a valve that turns off the water to the heater core when AC is on. It otherwise is open to allow for flow to assist in avoiding cylinder head hot spots during warm up. The supply hose goes from the intake manifold to the valve mounted on the wheel well, to the core and then return from core to the radiator. You need the AC vacuum lines in working order for the valve to correctly function. I had to trace my lines to locate spits at the dash HVAC control. Once repaired all worked great.
PbFut is offline   Reply With Quote
