Control arm rubs brake disc
1971 C10 Stepside 350ci TH400
I have replaced every component of the front suspension with new parts. (Stock height, stock aftermarket control arms.) When the truck is on the lift, there is plenty of clearance between the outside tip of the left lower control arm and the brake disc. When the truck is lowed to the ground, the outside tip of the control arm rotates up and rubs on the brake disc. This is with no alignment shims in. With alignment shims, the clearance is less. Any ideas or suggestions? |
![]() ![]() Join Date: Jul 2002
Re: Control arm rubs brake disc
Could be just the casting. Not sure otherwise. May have to do what lowered guys do and that is grind down\shave the end for clearance.
Post Whore
![]() Join Date: Feb 2016
My new aftermarket lower control arms had the same issue. I had 71-72 factory spindles on my 67. The shape of the new lowers was different than ones that were on my Burban.
Link to what I did. Post 718. http://67-72chevytrucks.com/vboard/s...698377&page=29
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks. I don't really want to grind the end off. I'm trying to figure out why this is happening, especially since the right side has enough clearance. I may have to pull out the grinder anyway.
#5 | |
But there are certain instances where things don't fit perfect, but good enough to sell. I understand someone with rubbing mechanical parts may vehemently disagree that this is "good enough", but I'm sure the bean counters are in charge of what is and isn't good enough. Just an idea on why some "correct" parts don't always fit like factory stuff. |
#6 | |
Post Whore
If I remember I will look up the lower control arms in my Hollander Exchange manual to see if there is a difference in the 71/72 and the earlier arms.
I'm sure the problem is just the fact that you have aftermarket control arms.
When these parts are manufactured in another country, they are duplicated, but not always in an exact manner. I rebuilt the entire front end on a 3/4 Chevrolet 4X4 pickup a couple of years ago. Replaced upper and lower control arms. Had to use aftermarket,O.E. was obsolete. I had this thing tore apart in someone else's garage, had to hurry. The control arms worked and fit, but tool A ALOT of modifications to work correctly. Man, I still can't believe I took on that job......... |
![]() Join Date: Jan 2007
Could be the disc backing plates are flipped?
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Jun 2022
If you're on a mac, you can us sips to fix these rotated files "sips -r 180 ./IMG_5162.jpg -o IMG_5162_rot.jpg"
Blue 67
![]() Join Date: Apr 2004
I had this exact issue not with my 67 pickup but with my 72 Nova when I replaced the control arms with aftermarket tubulars. After many head scratching and researching, I found out that specific unknown manufacture used a bigger (wider and taller) tubing section for the ball joint! I bought these from POL site. After seeing many other tubular arms online, I saw they all had some sort of notch or cutaway in that area which would create enough space for the rotors. I ended up copying what I saw online and notched mine!
I hope this make sense.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
![]() Join Date: Apr 2016
I am just curious, what is the purpose of or attraction of replacing original control arms with aftermarket ones on a C10?
Post Whore
I've checked and now I finally remembered to post my findings.
The Hollander Interchange book does show different numbers for 71-72 control arms. I'm pretty sure GM didn't do that because they were bored. ![]() I would bet that most if not all the aftermarket stamped control arms are the 67-70 style.
#13 |
Post Whore
In my case I removed my highly modified factory arms when I removed the air bags and went back to springs. I had gotten the aftermarket ones as part of a swap meet deal with a bunch of other stuff several years earlier. I think I was into them about $30. I'm sure couldn't get a used pair for that, not to mention the time and travel involved.
#14 |
![]() Join Date: Feb 2001
I had a simliar isue - My center link was on backwards.
Turned the Center-Link around and fix my issues.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#15 | |
I'm not able to envision how the center link and tie rods could affect control arm touching the disc or not. |
#16 | |
#17 |
That's a good question dmjlambert. I would never replace oem with aftermarket, but my original lower arms were cracked where the mounting shaft goes thru.
#18 |
I believe the aftermarket arms I bought from Summit were just junk.
I've always said, "Custom parts are called "custom" because you have to customized them to make them fit. |
#19 |
I agree HO455.
Thanks everyone. I will post what I had to do to fix this. |
#20 |
Well, I researched possible causes, looked at many photos, talked to people, talked to Summit, took the suspension apart and looked for a cause, and racked my brain.
I finally took a small sledge and reshaped the end of the control arm. This did the trick. Oh yah, the passenger side started rubbing also. |
#21 |
Sometimes you just need a BFH to fix it. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
