wanted blazer jack setup
Looking for a stock jack setup that mounted behind the drivers seat in blazer.
email me with info. cheyennek20@comcast.net thanks.
Bob |
the jack doesn't mount behind the drivers seat only the handle and lugwrench do the jack mounts in the back by the spare tire at least it did on the 71 2wd that i had
![]() Join Date: Jul 2001
Not sure but if the jack is the same for a blazer (don't see why it wouldn't be) I have an original jack and a folding handle to go with it. PM me if interested.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
stock jack
I guess thats right the jack itself mounted somewhere else but handle and lug wrench I believe mounted behind drivers seat with some type of brackets. Maybe some one else has pictures. Maybe I can use truck pieces if I had correct brackets and picture of mounting proceedure.
Bob |
Bob, Try doing a search for "blazer jack" or similiar. I remember within last couple weeks someone posted a pic of a blazer floor with a jack handle and lug wrench mounted to the vertical floor pan behind the driver's seat. Maybe that might give some insight.
the jack and lugwrench are the same as a trucks but the handle is shorter used only in blazers
Heree is a ling to the other topic http://67-72chevytrucks.com/vboard/s...ghlight=spring No one has pics yet.
Earl 68 2500 4x4 GMC Burb |
picture of jack or mounting hardware
I looked at old posts and couldn't find jack pictures.
Bob |
depended if the blazer had a rear seat where the spare tire and jack mounted. but yes the handle does go behind the front driver seata. jack and tire was behind the rear most seat.
69k5 |
