LS upgrade Turbo placement + intercooler setup
Hey Guys
How have you placed or routed your Turbo? and your IC? i am thinking about MILD turboing my C10 once it gets the 5.3 treatment. Its not my 1st turbo LS build i just need visuals of how you set it up. i use Truck Accessories! what manifolds did you use? I have the AC on the pass Side so i thought about setting the turbo up on the DRIVER SIDE? where did you cross over? i thought about the front X over since my Truck is low. IC i want to tuck it behind the bumper, WITHOUT Cutting anything! i dont need a HUGE IC since i just want to run low 6-10 psi max to have a reliable DAILY turbo truck. i want to use what i have and keep it on a Budget: - truck manifolds= mod them Or i have forward facing ebay 3" Vband headers - Intake with 102mm TB and 55lb/hr injectors (based on Calculator this should bring me up to 750Hp on Gasoline ( im ok with 550-600 thats plenty) ((based on calculator)) - i run a th400 i would just change the torque converter. (jegs brand 2300-2700) - 5.3 with gen4 internals SBE , summit 8701R1 cam NSR |
| Bookmarks |
