09-03-2023, 11:02 PM | #1 |
taking apart a 62 dash cluster
has anyone taken their dash cluster apart to clean it up? anything surprising jump out when you unscrew it and separate it? here is a pic of mine.... figured id clean it up and paint while i have it out working on a wiring issue.
09-03-2023, 11:29 PM | #2 |
Revitalizing a 6T C10
Re: taking apart a 62 dash cluster
this is for the later trucks, but is very similar from my experience ...
How To Restore and Detail an Original Gauge Cluster
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
09-04-2023, 12:35 AM | #3 |
There are wee rectangular rubber insulators - watch for those to fall out. And the bulb surrounds and lenses.
I went Classic Instruments on my '61, which uses the original bezel.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-04-2023, 10:06 AM | #4 |
thanks 60 and skinny... on mine it doesn't look as complicated with all the gauges and such. seems like a handful of screws to separate the cluster into half so it doesn't seem like i will have to deal with too many little pieces. but will be looking for those rectangular pieces skinny talk about. thnx
09-04-2023, 11:34 AM | #5 |
Nothing fancy on them. Unless you are stripping the speedo unit into pieces. I only removed the backing plate and carefully cleaned and relubricate. Did mine about a year ago and added a temp and oil pressure gauge.
Painte mine silver on inside and silver on the lens engraving. Then 2 hrs of elbow grease to polish it up. Went with yellow led bulbs for lighting. Vdo electric gauges, temp gauge i had was actually for oil temp but i had it, found a place that it works.and no extra monies spend. Last pic is where i am with center of dash to hide the butchering that so many have experienced. Still a work in progress there, Cheers. Adriaan. |
09-04-2023, 01:42 PM | #6 | |
thanks |
09-04-2023, 01:55 PM | #7 | |
Cheers. Adriaan. |
09-06-2023, 11:15 AM | #8 | |
I do have a image of wiring schematics that i used when tracing my wires, it does show on there that pink and brown is for gen light. Your cluster looks good. Its wonderful what some time spend on cleaning and detailing on things can do. Cheers. Adriaan. |
09-04-2023, 07:27 PM | #9 |
Place it face down on a clean white towel. Remove the screws and take it apart in layers. Plast-X does real well with polishing the lens.
09-04-2023, 09:28 PM | #10 |
wow...what a difference a little bit of time makes. thanks for the help on taking it apart. ill pant the back panel gray as well like the bezel when i paint the inside of the cab.
09-04-2023, 09:33 PM | #11 |
Looks great.
09-08-2023, 10:38 PM | #12 |
Heres another question... can anyone tell me if this is a stock cluster and if so what year? im trying to find a new harness for it but it appears AAW and other wire harness companies have never heard of a dash cluster that has two gauges and two warning lights. thus dont know what wire harness ill be needing. my cluster has two plugins... one with 4 wires other with 6. 61 and 62 harnesses either had 3 and six or 4 and 5.
09-09-2023, 01:42 AM | #13 | |
09-09-2023, 06:57 PM | #14 |
the 3 i looked at looked like that. only difference was the harness plugs. hard to tell with the wire coloring from that picture and what i got on the dash.
09-10-2023, 01:23 AM | #15 |
it looks right but hard to tell how many tabs are in each plug.
09-10-2023, 02:57 AM | #16 |
Unfortunately thats the only image ecklers shows on their website, zooming doesnt help much . And the ship it directly from a supplier so they wont have one to view directly. I think it is from american auto wire.
09-11-2023, 09:12 PM | #17 |
You have an idiot light cluster. Full instrument cluster looks like this (with optional tach).
Contact M&H wiringharness.com |
09-11-2023, 10:22 PM | #18 |
09-11-2023, 10:25 PM | #19 |
You can purchase a new harness for a truck with warning lights and it will work with your cluster. The warning lights will have two wires running to the coolant temp warning lights. Since you have a gauge, you can just use one wire from that two wire plug at the warning lights/gauge. That's what I did with my 63 when I swapped clusters to have a temp gauge.
You might have to move the temp wires around on the plug to match up with the correct wire from your temp gauge sender, but a small, flat blade screwdriver can easily pop the terminals out of the plug
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-12-2023, 12:18 AM | #20 |
perfect.. thanks for the info DP and CW
