Old 09-04-2023, 06:46 PM   #1
bikertim
American Autowire Megafuse Location
Doing a complete rebuild on my 70 C10 short bed step side -- LS 6.0, Holley Terminator X Max, 4w disc with hydrostatic boost, Vintage Air AC, American Autowire wire harness, Dakota RTX gauges, etc. Mocking everything up prior to disassembly for paint. Struggling with where to mount the Megafuse which comes with the American Autowire harness. Any good ideas out there? Pictures would be awesome! Thanks in advance for anyone willing to help!
bikertim is offline   Reply With Quote
Old 09-04-2023, 08:19 PM   #2
LS short box
Re: American Autowire Megafuse Location
Not American but Painless. I'm guessing they are similar. Pic of my 68. The maxi fuse is just below the heater box.
LS short box is offline   Reply With Quote
Old 09-04-2023, 11:16 PM   #3
bikertim
Thanks for the response! Trying to hide everything as much as I can..
Old 09-05-2023, 01:50 PM   #4
HalfBrit
Located mine on the radiator support, behind the battery.
HalfBrit is offline   Reply With Quote
Old 09-05-2023, 04:33 PM   #5
LS short box
Since you have the Autowire harness its fairly easy to hide all the wires. I removed the stock fuse block. Then I filled the hole. I moved the Painless fuse block back a bit from the firewall. Then I made a new small hole for the front wiring harness. Ran all the front wiring harness wires down the frame up to the radiator support. And then ran the rear harness out the same hole back along the frame rail. The engine harness I ran down the back of the engine and thru the fire wall. Mounted the ECM and fuse block behind the glove box.
Old 09-07-2023, 09:32 PM   #6
MikeB
MikeB's Avatar
I didn't do the wiring like AAW wants you to. I thought 6 gauge wire was overkill for my system, and it's virtually useless to have 175 amp fuses protecting 6 gauge and 10 gauge wire. I just used one 60 amp fuse protecting 8 gauge wire between battery and alternator, and no separate fuse on the 10 gauge fuse panel feed wire.
I used 8 gauge wire between battery and alternator because the highest current draw I've ever measured from battery to rest-of-world is around 40 amps. And my stock system used 12 gauge wire and and a fusible link, neither of which looked overheated after 54 years.
So, 8 gauge wire from battery to mega-fuse, and then across the core support to a distribution block. The circuit breaker on the top right of the picture powers a Vintage Air A/C system through a relay.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-09-2023, 08:04 PM   #7
bikertim
Nice clean looking wire setup -- thanks for the advice!
Old 09-11-2023, 10:49 PM   #8
PowerdbyChevy79
PowerdbyChevy79's Avatar
That looks good.
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 09-12-2023, 12:13 AM   #9
Spf79
Spf79's Avatar
I'm in process of wiring my project & ended up changing the 100 amp fuses to automotive breakers. I hid mine below my battery box... I thought to myself that if that fuse ever went out and stranded me on the side of the road I would be so frustrated with trying to change it out that I would rather see it burn & collect the insurance money. Lol. Not sure if the breakers are a good idea or not, but they look clean.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 09-12-2023, 12:03 PM   #10
MikeB
MikeB's Avatar
I have a spare fuse and wench in my glove box, but I think a proper circuit breaker might be best. I mean, they seem to work well in headlight switches. What brand/type breakers did you use?
Then again, a fusible link served the truck well for 54 years. I did replace it in the mid-90s. It wasn't blown but was looking a bit ragged.
The Internet is full of pros and cons about fuses, breakers, and fusible links. There's also a post on The H.A.M.B message board by an American Autowire employee defending their use of 175 amp fuses, saying they worked with Littlefuse to come up with the best solution.
Mike
Old 09-12-2023, 06:51 PM   #11
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I hid my AAW megafuse upfront near the bottom of my radiator on the crossmember. It fit up there well, and I drilled and tapped the holes with either #8 or #10 button head capscrews. Then cut of the screws after they stuck through and dabbed them with black paint. It worked well because all wires were down low and tied in nicely with my AAW kit. I wanted everything in my swap hidden. Take a look at my 70 K10 build if you want. Link is in my signature.
Sorry for the picture, but I don't have a good one. If you want I can take a better picture over the weekend.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-12-2023, 07:00 PM   #12
RodnRudy
RodnRudy's Avatar
A friend of mine did the same on his 67. Clean, simple and close to the battery.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 09-13-2023, 09:52 AM   #13
MikeB
MikeB's Avatar
Well that's not something you see everyday. It's certainly out of the way, though. I just hope you don't drive that K10 in the mud!
On another note, the AAW 6-gauge charging circuit would be much easier to locate on a vehicle like a square body, with the alternator on the passenger side near the battery. The 6 gauge wire is tough to route from one side of the engine compartment to the other.
Mike
Old 09-15-2023, 09:21 AM   #14
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I made this panel for the mega fuse and fan relays to mount to the core support. All the wires run from the drivers side vent up through the fender.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-15-2023, 01:22 PM   #15
MikeB
MikeB's Avatar
Very nice work.
Mike
Old 09-16-2023, 07:19 AM   #16
PowerdbyChevy79
Looks clean... nice work.
1966 C10 "Mary"
Old 09-30-2023, 08:40 PM   #17
bikertim
Wow that looks like a work of art! Great job!
Old 10-01-2023, 07:17 PM   #18
Accelo
Accelo's Avatar
This is where I installed mine.
Accelo is offline   Reply With Quote
