72 EEC question
Afternoon Guys I've decided to keep the gas tank in my cab my truck has that EEC system when me and my son took this truck apart 5 years ago we didn't take any pictures of the in cab fuel system I've read some threads on this site can someone post me some pictures of this system or acouple of threads i can see what some of you guys did what line goes where and without the canister what I can use on the vapor line under the cab Thanks Guys
Re: 72 EEC question
I don't have any pictures of my EEC system.. Sorry, I'm not much of a camera bug and
don't "photo document" my work. The charcoal canister and the line along the frame had already been removed when I got my truck.. As you know, the vapor line connects to the tank at the nipple on the upper passenger side corner. The line runs up the B pillar, makes a U turn and comes back down. It exits through the floor and a rubber hose joins it to the line running forward on the frame.. On mine, I installed a conventional metal fuel filter on the vapor line, mainly to keep insects and debris out. Also the vapors are released under the cab, not inside it,. I might also add, EEC systems don't require a vented gas cap. Last edited by RustyPile; 09-08-2023 at 12:23 PM. |
Re: 72 EEC question
Morning Thanks for the response what about the little nipple sticking out of the drivers side of the tank does that go to the Nipple on the tank filler pipe with a rubber hose my floor panda were gone when I got this truck I've installed new pans where about on the floor do the line go through also does the vapor line and fuel ⛽️ line exit the floor at the same spot. Thanks Never Give Up
Re: 72 EEC question
'67 GMC 2500, 292, 4spd, AC |
#5 | ||
Re: 72 EEC question
I think these lines are available pre-formed, I don't know for sure.. I have tools for forming/bending and flaring tubing so I rolled my own. |
#6 | |
Re: 72 EEC question
#7 | |
Re: 72 EEC question
#8 | |
Re: 72 EEC question
I had a few extra sitting here by the laptop ...........,,,,,,,,,,,(hint: Keep the extras for later) Enjoy! ![]()
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
#9 | |
Re: 72 EEC question
I guess the link is time sensitive. I did a forum search for "EEC" and found a ton of threads on the topic. Looked at a few and most had drawings of the hoses and others pointed out differences for the different years. If you are going to plug off these hoses and not use the cannister, you are going to have to use a vented gas cap.
Re: 72 EEC question
Thanks Guys for the EEC information I've learned alot Great site 👌
