Old 09-09-2023, 10:14 PM   #1
K10-Kansas
K10-Kansas's Avatar
Replaced mechanical oil gauge with electric
When I bought my truck there was oil all over the back of the dash. I cleaned it up and put in a new gauge cluster. The oil began leaking again and I could have just replaced the line to the gauge cluster but figured it would be easy to put in an electric gauge.
I put this in a 1971 K10 with the stock cluster.
I bought an electric ACDelco Oil Pressure Sending Unit
https://www.summitracing.com/parts/ADO-D8034
Bought an electric gauge from LMC for a 78-79 c10 https://www.lmctruck.com/1973-91-che...pressure-gauge
I had an oil electric wire off of my American Auto Wire harness but you could just run a wire straight from the gauge to the sending unit. I pulled the old mechanical sending unit. Put in the electric. Ran brown to ground, ran 12v pink, and blue in my sending wire.
I cut out the full circle from the stock cluster so the needle wouldn't get hung up and to show the whole gauge.
I drilled 3 holes in the back cover or the gauge cluster to hold the gauge in place and to connect to the wires and put little grommets in the holes.
I colored the lettering on the gauge with a black permanent marker.
Everything works perfect. Only mistake I made was I should have taken the plastic lens out of my gauge cluster because when I cut the circle out, hot metal marked up the lens.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
K10-Kansas is offline   Reply With Quote
Old 09-09-2023, 10:57 PM   #2
weq92f
weq92f's Avatar
Re: Replaced mechanical oil gauge with electric
That looks great! No more oil plumbed into the cabin!
Only you will notice those scratches.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-09-2023, 11:07 PM   #3
K10-Kansas
K10-Kansas's Avatar
-klb
Thanks. Yeah, and if they bug me, a new lens is not too expensive and it's easy to put in.
Old 09-10-2023, 03:21 AM   #4
HotWheelsFan
HotWheelsFan's Avatar
Yea, and never do welding next to glass without covering it either...
HotWheelsFan is offline   Reply With Quote
Old 09-10-2023, 07:53 AM   #5
mkmc69
mkmc69's Avatar
Good idea. How does it look lit up at night, in comparison to the rest of the cluster?
mkmc69 is offline   Reply With Quote
Old 09-10-2023, 07:59 AM   #6
K10-Kansas
K10-Kansas's Avatar
Oh good question. I'll take a pic tonight and post it.
Old 09-10-2023, 08:25 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
True story. I had a few stray slag pellets come off a project I was welding next to a glass patio table. The look as I finished my project just to watch that glass shatter, priceless.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-10-2023, 08:48 AM   #8
K10-Kansas
K10-Kansas's Avatar
Here's the finished product before I put it back in the dash. Works perfect.
Old 09-10-2023, 01:32 PM   #9
HotWheelsFan
Very nice.
I had to insulate the hard line to my gauge, it transmitted engine noise into the cab.
Bob
Old 09-11-2023, 11:29 AM   #10
MikeB
MikeB's Avatar
That's some very nice work there!
I used an oil pressure gauge and sender from a square body truck, but forgot the actual year range. Had to re-drill and wire the 69 panel. I also replaced the ammeter with a voltmeter from a square body.
I have an LMC coolant temp gauge with numbers on it designed to fit 67-75 trucks, but I just can seem to make it read correctly, so haven't installed it yet.
Finally, I am using LED bulbs to light the panel, and to my surprise, none have failed in 2+ years!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-14-2023, 06:19 PM   #11
chiefcfd
chiefcfd's Avatar
I need to do this.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 09-14-2023, 06:30 PM   #12
68 C10 Driver
Looks great! Great job on the install/conversion.
68 C10 Driver is offline   Reply With Quote
Old 09-15-2023, 08:11 PM   #13
K10-Kansas
K10-Kansas's Avatar
Sorry, I forgot to post these. Wow, you can really see how badly I screwed up that lens by not taking it out before cutting the hole. I think I'll stop at LMC in the morning and spend the 40 bucks to get another lense.
Old 09-15-2023, 08:19 PM   #14
K10-Kansas
K10-Kansas's Avatar
I have a coolant temp gauge with numbers on it from a square body, but I just can seem to make it read correctly, so haven't installed it yet.
Looks like you didn't have to cut out a spot for the needle to move? On mine, the needle hit that half circle area.
Old 09-15-2023, 08:37 PM   #15
'68OrangeSunshine
'68OrangeSunshine's Avatar
Nice Dash Build. While I personally prefer mechanical Oil Pressure and Water Temperature gauges, I truly understand not wanting hot motor oil spraying inside the cabin.
I once forgot to reattach my OP sender line and got my tan suede boots stained.
Anybody else old enough to remember Hush Puppies or Acme Dingos? These were pull-on wellington-cut 10'' boots with a gum rubber sole. Looked good with White Levis.
Kaput.
Old 09-15-2023, 08:57 PM   #16
junksaver
Looks great!!! That's a good idea that looks factory when installed.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 09-16-2023, 12:21 AM   #17
MS66
MS66's Avatar
Is that the factory tach for a '71?
MS66 is offline   Reply With Quote
Old 09-16-2023, 02:04 AM   #18
Richard
No. A factory tach only goes to 5k. There is an aftermarket tach that is 8k.
Richard
Old 09-16-2023, 02:12 AM   #19
dmjlambert
dmjlambert's Avatar
I'm staying tuned to this thread to find out why that oil needle hits the half circle unless it is cut into a full circle, or if there is any alternative treatments to deal with that.
dmjlambert is offline   Reply With Quote
Old 09-16-2023, 04:04 PM   #20
mkmc69
mkmc69's Avatar
I like it. The lens is just a lesson learned part.
Old 09-16-2023, 10:01 PM   #21
K10-Kansas
K10-Kansas's Avatar
When I got my truck my bezel and gauges were destroyed so I got a new one from LMC
https://www.lmctruck.com/1967-72-che...-dash-clusters
Old 09-17-2023, 12:40 PM   #22
MS66
MS66's Avatar
Thanks.
