09-17-2023, 11:06 AM | #1 |
60-66 to 73-87 Transfer...
I have 62 GMC dually... ideally I'd like to transfer its power train and body over to a 73+ frame.. Cab n chassis to Cab n chassis.
Parts of like to transfer: Cab. Front clip. Engine. Transmission. Rear end. If possible to swap over I'd be looking for a 2wd with a 60 inch cab to axle. Mike |
09-17-2023, 01:55 PM | #2 | |
But Found Her 25yrs Later!
Re: 60-66 to 73-87 Transfer...
One is a VIN matter, but depending your State you live in, it may not matter. The other reason is the shape of the 73+ frames. I guess they bump up under the cab so it makes the whole truck sit higher on the frame. Probably look fine for a 4x4. . It's been said that the 73+ suburbans don't have this bump up and our trucks could potentially sit correctly, but I don't know if anyone has ever confirmed. . The most well known thread on this topic might be linked in the FAQ's.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-17-2023, 11:41 PM | #3 |
Here's the thread. It was in the FAQ's
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
09-18-2023, 11:40 AM | #4 |
Is your frame bad? Why do you want to switch them?
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
09-18-2023, 10:45 PM | #5 |
If your original frame isn't bad, your best course of action is to put the front suspension and rear axle from the squarebody on your 62 frame
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-20-2023, 04:49 PM | #6 |
On a square body truck frame you will end up with a 3" body lift unless you do some serious modifications
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
09-22-2023, 05:24 AM | #7 |
I was going to do the front end swap but looking closer my 62 frame is all beat up and starting to have soft spots... So I'd being saving a dying frame.. So I was trying to find out what I'd need to get for a frame to slide under the truck.
I don't want a square body powertrain I want the 62s powertrain fan blade to rear end. So figured if the front swaps why not the frames😂 Apparently that's not easily done shame they don't make much for dually parts. So I need a 60 inch cab to axle cab n chassis frame I can put the GMC V6/4spd/Diff into. Mike |
09-22-2023, 08:15 PM | #8 |
You could try to find another 60-62 frame, a 63-66 would work but the bed mounts won't line up and the frame horns where the bumper mounts will be different. Then 67-72 with the same mods needed with the 63-66 frame.
09-26-2023, 07:19 PM | #9 |
I need a dual rear wheel cab n chassis frame that is 60" cab to axle.
Mike |
