09-18-2023, 11:36 AM | #1 |
Fuel Gauge wiring location with factory single tank
Bought a 85 GMC 2500 4x4. 5.7, sm465, 208, SF14, 10 3.42 ratio standard cab 8'bed Yesterday. The truck was used as a airport truck then it was sold to a family who had it for 20+ years.
It runs drives and stops great. It has rust of course. But I really just want it for a deep snow winter ride. It has a few issues besides the rust that I will be addressing. One of those is that the fuel gauge does not currently work. Now I will no doubt eventually do a 5.3 swap and run a back seat out of a 2017ish truck. But this thing runs and drives currently. This year I really just want to fix the floors so its not throwing snow inside and refresh things so it's not going to leave me stranded during a blizzard. The sending unit on the drivers side is right between the cab and the bed and I can get my hand on the green and orange wires to see that they have been cut. I should be able to connect these to new wiring without dropping the tank. Green is the ground and the orange is the sending unit from the looks of it. But looking around I can't seem to find what I am assuming is going to be green and orange or orange and white wires going to the gauge. Looks like they ran a new taillight wiring when a newer bed was installed and the harness from the cab back was removed. Now I have a 91 cab and chassis R30 square and a 87 1/2 ton V10 square so I simply went up to the selector switch on the dash when going to single tanks on those. But this 85 does not have a selector switch. So where will I find the wires coming off the gauge preferably without cutting into the plug behind the cluster. (worst case I do this) Should I start behind the dash near the center of the dash? Would the gauge wiring be there? I am guessing it would run from the dash down the passenger frame by where the old selector would be. Or with a single cab single tank it could be ran down the center of the cab. Even skipping the dash all together and running next to the speedo cable. Before I spend hours searching and testing wires I thought one of you guys might know where to look maybe even if the colors change behind the dash etc. Thanks for reading and any help in advance.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
09-18-2023, 12:55 PM | #2 | |
Re: Fuel Gauge wiring location with factory single tank
The document that I copied the chart from also shows both terminals #7 and #18 are used for trucks with factory gauges, but I have no idea why. If the image is too small to read, try opening it here. http://forum.73-87chevytrucks.com/sm...ch=29746;image
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-18-2023, 06:07 PM | #3 | ||
From the back of the cluster, the fuel gauge sending unit wire should run down to the firewall bulkhead connector that is located behind the fuse box. The under-hood side of that connector is divided into 3 sections (engine harness, front light harness, and rear light harness). The fuel gauge sending unit wire comes through as part of the engine harness. From there, it should simply run down to the frame and back to the tank. |
09-18-2023, 06:47 PM | #4 |
Trucks dripping dry in the garage right now. I gave it a bath to wash off years of "sitting" grime as well as chase off spiders etc.
I am just going to pull the cluster then will splice off of 18(No factory tach). Run a new wire back and avoid any chance of a T or other cut connection. Thanks for the great help.
09-19-2023, 10:58 AM | #5 | |
Someone put a lot of time into those charts, but got it wrong. They also left out several pins and wires.
09-20-2023, 11:15 AM | #6 | |
Moderator
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
