Explaining High Beam Circuit?
I Installed Some Dapper Headlights. Look Pretty Good But The High Beams Are Staying On and Won’t Go Off.
Can Anyone Explain How The High Beam Circuit Works Through The Dimmer Switch. Do Both High and Low Beam Wires Send Power To The Headlight When The High Beams Are On? |
#2 | |
The Older Generation
Re: Explaining High Beam Circuit?
No, it's one or the other. I don't know anything about Dapper Lighting but I do know dimmer switches.... ![]() Did the lights work OK before? LockDoc
Its a New Build.
When I Hit The Dimmer Switch Before The Headlights Were Installed The Blue Indicator Light Would Bounce Back From To Hight Beam as It Should I Noticed With a Test Light Both Hi and Low Beams Had Power At The Same Time But I Gotta Double Check |
![]() Join Date: Jul 2011
LockDoc speaks truth, only one powered circuit in each mode. Green is high beam. BTW, what are you working on?
I too, know nothing about Dapper Headlights.. Here's a detailed explanation of how the dimmer switch works.. Its a single pole, double throw switch. The headlight bulb has 2 filaments and 3 terminals, one for hi beam, one for low beam, and the third is ground.. Each headlight has its own ground. A blue wire from the headlight switch brings voltage to the common terminal of the dimmer switch.. A tan wire carries voltage to the low beam bulb terminals. A green wire carries voltage to both the bulb's hi beam terminal and the hi beam indicator bulb in the dash. Voltage is not sent to both hi and low beams simultaneously, only one at a time.
To test the dimmer switch, disconnect the plug. Using a DVM, check continuity between the blue wire's terminal (common) and the other 2 terminals. Depressing the "button" selects continuity between the blue wire and the other 2 terminals.. Again, continuity between the blue and the others is selective, only one at a time. Any other results means the switch is bad. If the switch checks good, check your wiring again... |
Nothing to add here that RustyPile didn’t cover.
Thanks Guys. Working On a 69 C10
I ll Test The Dimmer WhenI Get Home. I Called Dapper Lighting and They Said They Seen This Before. They Said I Takes As Low As a Half a Volt To Trigger The Hi Beam To Stay On. Said Voltage Can Be Seeping From Somewhere Said To Check The Grounds. They’re Solid, And Dimmer/Headlight Switch. |
I went to the Dapper Lighting website:
https://www.dapperlighting.com/pages...-high-low-work If I'm understanding the concept, there is only one "filament" in the bulb. The dimmer switch is used to energize/de-energize a "shield" inside the bulb that changes the beam configuration from that one "filament".. The dimmer switch in our trucks switches between two separate filaments for hi and low beams. If I'm correct on how the Dapper system works, it's not plug and play, some wiring and switch modifications are necessary for this system to work.. |
![]() Join Date: Dec 1999
Lights are plug and play. Switching needed is done by the ballast harness (hid) or led driver harness (led) Check voltage at the stock headlight connector. If you have 12v at two terminals or 12v on one and a few volts on another, probably the dimmer switch is most likely bad. Dapper has a relay harness available to take load off the headlight switch that is mostly plug and play that would fix problem of "seeping voltage" as it isolates the lights from the switch and provides direct power from battery. But best to locate problem (dimmer?) It could be the old headlight switch causing a voltage drop as well. A DVM is your friend.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 09-22-2023 at 01:08 AM. |
#10 | |
#11 | |
Edit- you mentioned cost. Another thing adding to that is the glass lenses that will not yellow in a couple of years reducing vision and looking like C**P like the plastic ones.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 09-22-2023 at 03:40 AM. |
Cycle the dimmer switch with your foot about 20 times. You won't because nobody does, but the contacts get dirty and the switch stops working.
#13 | |
The easiest way to tell if you're having contact, or spade connector issues is by looking at the molded plastic connector cover for obvious hot spots. If that's the case, replace both the dimmer switch and the connector with new parts.
#14 |
Anyone who has WD40 should toss it in the trash. Dirty dimmer switch contacts don't make the switch bad--do we throw dishes away because they're dirty? No. Cycle the switch til it works.
#15 |
![]() Join Date: Dec 2009
On the website it mentions the diode wiring.
[Different vehicles use different systems for high beam control. The diode allows different vehicles to keep their high beams plug and play with Dapper Lighting headlights.] Have you checked that? Link: https://www.dapperlighting.com/pages/diode-instructions
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
| Bookmarks |
