Old 09-30-2023, 02:05 PM   #1
dboboltz
1970 Steering column - what is this?
Hello all,
I have a 1970 GMC - was a three on tree, converted to floor shift. I purchased a floor shift, tilt column to replace OE column. The pic is from my OE column, the CPP column I purchased does not have this. What is it for?, and do I need to move over to the aftermarket column or disregard? Thanks
dboboltz is offline   Reply With Quote
Old 09-30-2023, 02:24 PM   #2
chewychevy67
Re: 1970 Steering column - what is this?
That's for your reverse lights
chewychevy67 is offline   Reply With Quote
Old 09-30-2023, 06:03 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
And whatever you do don't lose those screws. "factory replacements" don't work.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-30-2023, 08:37 PM   #4
dboboltz
Thanks for the info - will not be needed based on my install.
Dan
