72 K5 sending unit
I have the 30 gallon I believe aftermarket tank, does anyone know if it takes the stock sending unit or where I could find the one needed? I'd like to have it in hand before we drop the tank. Thanks!
Re: 72 K5 sending unit
The stock tank is roughly 13" tall. If your tank is about the same, it should work.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson 1972 K/5 Blazer CST 4WD 1963 Corvair Monza Spyder Turbo convertible 1995 Camaro Z/28 |
Thanks, I guess I should have dug up an image before I posted. I've only seen one other before, and that was just a picture. Supposedly it's an aftermarket shaped like a fuel cell.
Yeah, that would be a very different thing. A stock sending unit wouldn't fit that. You'll probably have to try to figure out who the manufacturer is.
![]() ![]() Join Date: Jul 2003
I have a very thick wall 37 gallon aftermarket fuel tank installed by me in 1996. It has a very small gauge unit, and its bolted to the top of the tank.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks guys, discovered its an old Hickey, now I need to find a unit deep enough for it.
My tank is very similar in design and construction to the Hickey pictured, but was bought new by me in 1996 through JC Whitless.
Doing a Google search on that image brings it up as an RCI fuel cell. Searching for an RCI fuel cell sending unit brings up dozens of vendors. Here's an example:
https://www.summitracing.com/parts/rci-7060b
| Bookmarks |
