Old 10-07-2023, 06:03 PM   #1
pjmoreland
pjmoreland's Avatar
Tilt Column Turn Signal Lever Question
I have noticed that most parts vendors list two different turn signal levers for non-tilt and tilt applications. I purchased a factory tilt column recently, and it came with what appeared to be the original turn signal lever. It is exactly the same as the turn signal lever I have on my non-tilt column. The parts catalog doesn't list different levers or knobs for tilt and non-tilt columns. It just lists the following two part numbers:
3909580 Lever
3782965 Knob
What is the difference between the tilt and non-tilt turn signal levers sold by most vendors?
pjmoreland is offline   Reply With Quote
Old 10-07-2023, 06:06 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Tilt Column Turn Signal Lever Question
The difference is about 12 Dollars, Pat.
Old 10-07-2023, 06:07 PM   #3
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
The difference is about 12 Dollars.
You win! Haha
Old 10-07-2023, 08:11 PM   #4
'68OrangeSunshine
Interesting that the first vendor lists the same Gear Shift Knob (Floor Shift) for 1934 - 72.
The knob might be the same but the SM 420 and SM 465 [1968 - Later] have different 4-On-the-Floor patterns. 420's Reverse pulls toward the driver, 465's pull away from the driver.
Old 10-07-2023, 08:15 PM   #5
pjmoreland
pjmoreland's Avatar
Maybe they get around that issue by not printing a pattern on it.
Old 10-08-2023, 12:55 AM   #6
'68OrangeSunshine
Theft Deterrent.
Old 10-08-2023, 02:33 AM   #7
pjmoreland
pjmoreland's Avatar
I looked through dozens of photos of tilt columns in the classifieds section, and I get the impression that tilt columns may have come with a turn signal lever that has less of a bend in it than the non-tilt version.
Old 10-08-2023, 03:33 PM   #8
'68OrangeSunshine
Shape may have changed annually in the Car Division...
Old 11-13-2023, 08:37 PM   #9
pjmoreland
pjmoreland's Avatar
In case anyone else is interested, I ordered the "tilt" turn signal lever from GMCPauls. They ended up sending me Counterpart 67-13305, which is just a regular non-tilt lever. I contacted them about it and they said the tilt style isn't available anymore. I then ordered the "tilt" lever from Classic Parts, and I indeed got a lever that is straighter than the regular one. It is made by Trim Parts and it is part number 9300. The Classic Parts part number is 29-563. The plastic knob is a little more blocky on the small end than an original.
I am looking forward to installing this lever because the non-tilt lever I have on my truck is too close to the steering wheel.
I am looking
Old 11-14-2023, 12:45 AM   #10
pjmoreland
pjmoreland's Avatar
Here are some photos of the tilt turn signal lever installed. I've also included some of the original lever for comparison.
Old 11-14-2023, 07:04 PM   #11
'68OrangeSunshine
Hey Pat, could someone have just heated the bent lever with a torch and whacked it straight on an anvil with a BFH, or would that flake off the chrome?
Old 11-14-2023, 08:40 PM   #12
pjmoreland
pjmoreland's Avatar
I figured it would flake off the chrome. That's exactly what GMCPauls said to do.
Old 11-14-2023, 09:22 PM   #13
'68OrangeSunshine
I'm procrastinating on overhauling my original Steering Column. I've had the original, once-Fawn wheel off for a rebuild with 2-part putty. There's a Seafoam Green 3-spoke wheel on now. Just can't find a perfect match Fawn spraypaint.
Other system-related issues are:
A] Horn relay constantly clicks. Horns are disconnected. When I tried a new T/S harness, the gripe didn't go away. One of the BBs in the upper bearing race got lost. I'm thinking an imprecise distance somewhere in the Column won't let the horn switch operate normally. Also bought the lower bearing, but that requires pulling the whole shaft. With no horn, I have to accept the errors of others silently.
B] My OEM turn signal lever fell out. The screw worked itself loose. The T/S Lever is just loose on the dashtop. I keep it in sight so I don't lose it. To signal turns [esp. at night] I have a pair of high visibility construction gloves -- Orange canvas, white leather and white reflective stripes. Manual turn signals just like the old days. Somewhat difficult with Manual Steering and Manual Shifting.
I have a simple no-shifter steering column out of a junkyard. Has a very shot '69- later wheel [or the remains there of]. I can cannibalize it for any pieces of inobtainium that are missing from my original column.
Old 11-14-2023, 09:25 PM   #14
pjmoreland
pjmoreland's Avatar
It's always an adventure digging into a steering column.
Old 11-14-2023, 11:22 PM   #15
'68OrangeSunshine
YUP
Old 11-15-2023, 01:20 AM   #16
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
I am guessing from looking at a few pictures of tilt vs non tilt columns, the level mount is lower in the bell on a non tilt column and then on a tilt column it was moved up to allow for the tilt mech so that way the end of the lever landed roughly in the same position regardless.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 11-15-2023, 01:28 AM   #17
pjmoreland
pjmoreland's Avatar
I agree. The difference in bend is more than enough to make up for that small difference. On a side note, I am noticing that it is easy to hit my left knee on the tilt turn signal when releasing the clutch while making a left turn.
Old 11-15-2023, 02:38 AM   #18
'68OrangeSunshine
I saw a pair of those Orange/White/ 3M reflector gloves in an O'Reilly's. Then you wouldn't bump your knee.
Old 11-15-2023, 02:43 AM   #19
pjmoreland
pjmoreland's Avatar
Perfect!
