Old 10-10-2023, 10:05 AM   #1
Ramiro0727
TAC connector
I'm trying to troubleshoot the TAC connector from the wiring harness. To see if im getting voltage to the pink wire. I'm not sure if I'm doing it correctly.Can someone let me know how to properly do this. Also I want to check for voltage to the gas pedal and throttle body. I'm suspecting we have a bad wiring harness.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 10-11-2023, 10:18 AM   #2
Jason Banks
Jason Banks's Avatar
Re: TAC connector
I would highly recommend you buy this book:
https://www.amazon.com/dp/1613257015/
It has detailed drawings of all the wiring and connectors. It should tell you where every wire goes.
You used to be able to view most of the book on Google Books, but they have now limited it...or may be that's just for me, since I have looked at it so much. Here's link https://www.google.com/books/edition...0/UJdwEAAAQBAJ
Jason Banks is offline   Reply With Quote
Old 10-11-2023, 04:57 PM   #3
Ramiro0727
Re: TAC connector
Thanks Jason for the link. Well.i was troubleshooting the pink wire correctly. In my harness the wire is red. If I wiggle the wire around I get 12 volts. As soon as a stop I lose the voltage. So I figured the terminal on the wire. Going to replaced that teeminal.on that wire. To see if that helps. But according some of the wire colors don't match the colors there supposed to be. Once I fix that wire. Hopefully I can the see if the correct wires have 5 volt reference. So we can get the gas pedal working.
Ramiro
Old 10-11-2023, 09:05 PM   #4
Jason Banks
Re: TAC connector
I had read reviews about the harnesses before i bought one, that talked about people having some wires swapped, but they said their tech support helped them resolve it quickly. I went ahead and ordered anyway and didn't have any problems. If I remember, this is your 2nd harness from them too...
Another great resource is the LT1swap.com site ... this page - https://lt1swap.com/2000harness.htm
I think I recall you are DBW, here's the page with all the PCM pinouts there - https://lt1swap.com/2004vortec_pcm.htm
If you are DBC it's here - https://lt1swap.com/99-02_vortec_pcm.htm
Good Luck!
Old 10-12-2023, 10:44 AM   #5
Ramiro0727
Re: TAC connector
Good Luck!
Thanks Jason, Hopefully replacing the terminal on the 12 volt wire to the Tac Module will get this truck going. So I can have gad pedal responce.
Ramiro
