Old 10-11-2023, 11:55 AM   #1
no1udknow
no1udknow's Avatar
Has anyone put a 3.6l in their c10?
Hey all, looking at options s for my next c10 project. I recently bought a 2021 gmc acadia and it has a 3.6l with 300+ hp. The acadia rips, and on top of that it gets 27mpg on the highway.... With gas prices and the fact that I want it as a daily, I am considering a similar power train. 5.3l are great... but the mpgs just aren't there. And to make things worse this acadia will smoke my 5.3l avalanche in a 1/4 mile. Let me know your thoughts.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 10-11-2023, 01:16 PM   #2
Joyridin
Re: Has anyone put a 3.6l in their c10?
How much does your 5.3l Avalanche weigh compared to your C10? Most new trucks are quite heavy.
My Gen 5 L83 in my C10 gets about 20-22 mpg on the highway, and that is with a very large cam, 6l80, and 3.70 rear gears. I bet it would hit 25 mpg if I had 3.08 rear gears.
If you are still stuck on the 3.6l, you may want to go to HP Tuners web site and see what you will need for a computer etc. That might be the hard part as 2019 and newer require a lot more $$ to unlock and program the computer than 2018 and older.
Joyridin is offline   Reply With Quote
Old 10-11-2023, 01:40 PM   #3
dagnabbitt
dagnabbitt's Avatar
Sounds like an interesting project. Eventually LS engines will be too hard to come by to be an economical swap. Where I am they are already kind of difficult to find.
I understand your interest: my Yukon XL got hit in front of my house and they gave me a 2023 rental car while it is being repaired. This thing will blow the doors off of everything else I own. If you could delete the traction control it would smoke the tires for miles.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-12-2023, 08:45 AM   #4
tim_mc
tim_mc's Avatar
Maybe find a later model GMC Canyon or Chevy Colorado with the 3.6l (and 6-spd auto) that's been wrecked?
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 10-12-2023, 10:20 AM   #5
michael bustamante
michael bustamante's Avatar
if you pull the trigger, change that thermostat first, they`re a bear to get to and seem to be the only issue wiith these motors
1967custom
michael bustamante is offline   Reply With Quote
Old 10-12-2023, 11:48 AM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Has anyone put a 3.6l in their c10?
The timing chain/tensioners are issues on neglected or high mileage 3.6's.
Old 10-12-2023, 12:33 PM   #7
MARKDTN
A good friend and his buddy just drove Atlanta GA to Spokane WA in a 2022 Denali pickup with the 6.2 (belongs to the buddy). He says they averaged mid 20s mpg for the trip pulling a trailer empty 1 way and with a Corvette on it coming back. Apparently the 10 speed with the right gear will really get the mpgs. The only 6.0s or 6.2s I have been involved with previously got bad mileage. Anybody else out there with a newer 6.2 with the 10 speed transmission that might confirm that? A newer 6.2 is 420HP/460 Torque.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-12-2023, 02:49 PM   #8
Wrenchbender Ret
I have a 2010 Buick La-cross with a 3.6 as a dd. It runs strong & gets 26 mpg on the road.
It feels like a rotary engine. There is no vibration. I usually drive conservative but I got on it the other day & it sounded like the muffler opened up on it. I wonder if it has some type of a system to do that.
I would not hesitate to put an engine like this in anything.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-13-2023, 08:06 AM   #9
chiefcfd
chiefcfd's Avatar
I have a 2015 Chevy High Country with the 6.2 and 8 speed transmission. On a recent trip to Florida the overall avg according to the computer was 22mpg. on the Interstate I ran 73-75mph.I will take that.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 10-14-2023, 10:50 AM   #10
old51sedan
old51sedan's Avatar
I take it we are talking about the same motor used in the chevy traverse and the Buick Enclave. I just sold a 2010 Enclave that I drove for 12 years, it had 288HP with a 160 MPH speedometer. That son of a gun had power, I towed a 6x10 trailer loaded back and forth to Florida for several years, at times I'd be doing 80 and not even knowing it. I liked it so well that I just bought a 22 model, it has 312HP with a 170MPH speedometer, I believe it has an 8 speed tranny. I believe they would be a wonderful motor, of course I like my 292 with the cast iron headers and the Holley also.
old51sedan is offline   Reply With Quote
Old 10-14-2023, 04:33 PM   #11
LS short box
I have a 20 Silverado 4x4 crew with the 6.2/10 speed combo. It will easily get 22-23 mpg on the highway. It's a great combo engine trans wise.
In regards to the 3.6 swap before you get too far I would check with some of the swap harness/ ECM reprogarmers companies to see if they can help. I would check with Speartech and Howell.
LS short box is offline   Reply With Quote
Old 10-17-2023, 05:49 PM   #12
Rust_never_sleeps
Rust_never_sleeps's Avatar
v6 generally makes most of its torque and power at higher rpms compared to a v8, which usually has grunt off the line that you might miss in a truck like these, especially loaded or towing.
Easy enough to pull up the power+torque graphs and compare.
Rust_never_sleeps is offline   Reply With Quote
Old 10-18-2023, 10:52 AM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Before you go down the 3.6 route do some research they are notorious for timing chain problems. They came in the 2010-15 Camaros and the v6 guys on the 5th gen site I frequent are always having troubles it seems. They have a tendency to have carbon issues too because of the direct injection, and crankcase gasses/oil from the PCV. Which is obviously a semi common theme with all direct injection. A catch can is a real necessity there.
Tyler
57taskforce is offline   Reply With Quote
Old 10-18-2023, 04:05 PM   #14
Rust_never_sleeps
it's an interesting point.
I never seriously considered swapping it in, but I did compare the power+torque of my '08 Infiniti 3.5 V6 to that of the LS9 out of curiosity, and it was eye-opening just how much more efficient a 21st Century mill is. Lighter too
Old 10-18-2023, 04:20 PM   #15
MikeB
MikeB's Avatar
Does anyone know if a 3.6 out of FWD and AWD vehicles like the Acadia can be used with a RWD transmission?
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
