Old 01-10-2004, 12:30 PM   #1
69_hafton
Sleep-Deprived
69_hafton's Avatar
Question Van tilt / floor shift question
I'm looking a going with a van tilt in my truck.
Just wondering though, if you can replace the section
where the shifter is on the column if you have a
shifter on the floor.
I've seen many that have just
removed the column shifter itself, but just wondered if it's
possible to remove/replace that section so that it
looks like the column belongs in a truck with 4 on the
floor.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 01-10-2004, 12:54 PM   #2
68cajun
68 C/10
68cajun's Avatar
take a grinder and grind off the nub. then a little bondo and some paint, and you will never know it was there.
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 01-11-2004, 02:42 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While I have not tried it yet, i'd bet you yould take the shifting collar off and replace it with one from a 4 speed non tilt truck.
Old 01-11-2004, 02:51 AM   #4
gonebad2
Merciless Butcher
gonebad2's Avatar
I have heard it's kind of hard to take a tilt column apart and put it back together again. I have never tried it. Hopefully someone on here knows more about it. I have also thought about grinding and filling also. I would use Kitty Hair ( similar to bondo but it's reinforced with fiberglass strands) instead of Bondo. It sands out real good. A little flat black paint and you could never tell it was modified.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-11-2004, 08:39 AM   #5
JimKshortstep4x4
Talking
The bezel from a non tilt column will not fit as they are entirely different.
Jim
Old 01-11-2004, 02:15 PM   #6
Rod
Collars are different.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
