Active Member
![]() Join Date: Jun 2023
Dash pad woes.
Can anyone tell me how to get the dash pad off my dash? I took the screws off the front lower lip, but its somehow still attached?
1969 CST10 |
![]() Join Date: Dec 2009
Re: Dash pad woes.
It also has nuts underneath.
Here's an old thread. Link: https://67-72chevytrucks.com/vboard/...al+of+dash+pad
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: Dash pad woes.
Get your hand up below the dash and feel for the nuts that run the entire length of the dash. Might have to remove the glove box liner. I removed the radiator for access. The cluster out also gives you room too.
71 C-20 07 Magnum RT AWD |
![]() Join Date: Apr 2016
Re: Dash pad woes.
Here you go. This is the only clear view of that underside of the pad and placement of the nuts. http://67-72chevytrucks.com/vboard/s...d.php?t=793182
