Old 10-16-2023, 11:03 AM   #1
Rg500gamma
Junior Member
Reproduction EDP primer panels
Most listed panels state EDP Weld through primer.
This is also the case with bolt ons such as hoods and fenders.
Besides skuffing them and wiping/tack cloth do they actually need a primer coat ?
Rg500gamma is offline   Reply With Quote
Old 10-16-2023, 11:37 AM   #2
Jason Banks
Jason Banks's Avatar
Re: Reproduction EDP primer panels
Absolutely.
The coating on most of the panels I have used is pretty thin and of unknown quality, NOT like what you would get on a modern OEM panel. I would actually recommend removing as much of it as reasonably possible and starting from bare metal.
Jason Banks is offline   Reply With Quote
Old 10-16-2023, 04:46 PM   #3
LS short box
I help at a body shop a couple days a week. On the aftermarket panels we scuff them with a red 3M scuff pad and yes they need a good 2K primer prior to any body work.
LS short box is offline   Reply With Quote
Old 10-16-2023, 05:23 PM   #4
jumpsoffrock
I live in wimpy CA with wimpy weather, and I have left EDP coated patch panels outside in the elements for 3-7 years and the paint got a hazey or dull, but it didn't simply flake off and completely rust.
I'm not suggested to forgo basic prep, but it doesn't seem totally worthless.
jumpsoffrock is offline   Reply With Quote
Old 10-16-2023, 07:34 PM   #5
Rg500gamma
Junior Member
Ok guys thanks. I will do the primer regardless.
Better be safe and have a better outcome.
I thought there was a chance of skipping the step
But going the lazy route would have bothered me with the chance of a poor job
Old 10-16-2023, 07:37 PM   #6
Rg500gamma
Junior Member
1 last thing
I have heard of doing epoxy primer as a 1st coat
Then urethane for a 2nd coat being it will not clog up the during the sanding process
Old 10-17-2023, 08:01 PM   #7
hugger6933
If you scuff the EDP with like 220 grit then do a couple coats of high build primer that is what I do on al the parts I change for newer cars and trucks. Now on aftermarket some parts the primer is not near as good and the OE of course take a little thinner on a rag and wipe it on the primer to see if it comes off on to the rag, if it does sand that crud off then do a 2 coats of epoxy then your high build. Jim
hugger6933 is offline   Reply With Quote
