Old 10-24-2023, 07:14 AM   #1
AlaskaK10
Junior Member
Rockwell T221 Sealed versus Non Sealed Bearings
Hi All
I am rebuilding my Rockwell T221 transfer case. I have two of these cases. One had an input shaft bearing failure and used shielded bearings on the input shaft like they were from factory from my understanding. The other T case used open bearings and basically seemed good except leaked oil around yokes due to wear grooves. I am tempted to defy the factory sealed or shielded bearings on the input shaft and go with open bearings. The good transfer case had been sealed at some time with rtv and the oil passages were partially or fully blocked with the stuff but bearings were still good. So what is the consensus on the sealed or shielded bearings use in these transfer cases?
AlaskaK10 is offline   Reply With Quote
Old 10-25-2023, 04:17 PM   #2
dieseldude4bt
Re: Rockwell T221 Sealed versus Non Sealed Bearings
The shield helps keep a little more oil on the bearing is my understanding of it's use.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 10-26-2023, 09:26 PM   #3
Short 3/4
Would be curious to see a picture of what you’re talking about. Not familiar with this, but sounds like an interesting question
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 10-27-2023, 04:51 PM   #4
AlaskaK10
Junior Member
Got a sheild on one side open on the other
