Old 10-25-2023, 09:35 AM   #1
SchmidtM
67 SWB Steering question
So my 67 and in a frame off state. I have a L31 and tranny from a 96 Siiverado both were crate buys and have 30K on them. So PS pump is a 96, I want to buy a tilt column. If I buy a new steering box and column what would be a good way to go? I have the original steering box but didnt want to limit myself. I dont wwant to skimp out but also dont want to go broke. lol Thanks for your help!
SchmidtM is offline   Reply With Quote
Old 10-25-2023, 10:37 AM   #2
cj847
cj847's Avatar
Re: 67 SWB Steering question
This info is worth what you paid for it.
I would use a 1980-1986 steering box. It has the metric threads and O ring.
cj847 is offline   Reply With Quote
Old 10-25-2023, 11:02 AM   #3
SchmidtM
80-86 truck box? or does it matter
Old 10-25-2023, 11:54 AM   #4
67swb72klb
67swb72klb's Avatar
It will bolt up you need to dimple the frame where the box mounts there are threads on it
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 10-25-2023, 05:16 PM   #5
Jason Banks
Jason Banks's Avatar
Kind of off topic, what is the deal with 1967 trucks that had factory power steering. How did the gear mount up if the frame need dimpled?
Or, are the 67 steering gears different? Maybe like the aftermarket ones now that don't need the dimple?
Jason Banks is offline   Reply With Quote
Old 10-25-2023, 09:14 PM   #6
Tomchev
67 had power assist steering not a power box.
Tomchev is offline   Reply With Quote
Old 10-26-2023, 12:30 AM   #7
chewychevy67
67 Steering looks just like in this thread. I believe. It uses a manual steering box and it connects to a pump and a hydraulic cylinder.https://67-72chevytrucks.com/vboard/...d.php?t=253657
chewychevy67 is offline   Reply With Quote
Old 10-26-2023, 07:44 AM   #8
SchmidtM
Wow, that thread was really interesting. So am I thinking correctly that if I have a power steering box and not all the additional that is in that thread someone upgraded my 67??
Old 10-26-2023, 08:12 AM   #9
SchmidtM
This has all been great info but I am still looking for choices in new steering columns
Old 10-26-2023, 08:41 AM   #10
Find a 71-72 Column (tilt if you desire that) and intermediate shaft. Best bet is finding an original column versus the aftermarket. I never jave bought a tilt beciase I never move the wheel from it's original position. Seems way easier ( to me) to find a non tilt automatic column and other folks seems to want tilt.
Old 10-26-2023, 04:49 PM   #11
LS short box
On my 68 C10 project I went with an Ididit tilt column. Worked well.
LS short box is offline   Reply With Quote
Old 10-26-2023, 06:11 PM   #12
LNP
Is there a lot of mods to do to make that column work?
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-28-2023, 08:19 AM   #13
tim_mc
tim_mc's Avatar
I first tried a CPP tilt column, but didn't like it. I wound up getting a rebuilt GM tilt column from Les (70shortfleet). Les does good work and it was worth the money. Ah, memories of modifying my '67 frame rail with a few well-placed swings of a 20lb sledge to fit the p/s steering box...good times.
For my steering gear box I went with a reman Lares 1075 with the later 3-1/4 turn ratio, but it seems a little sloppy. Swapping out the OEM 17" steering wheel to a 15" comfort grip really helped at higher speeds on the interstate. In the future I plan to upgrade to a Borgeson 800132 gear and maybe their rag joint eliminator (033152).
https://www.borgeson.com/Borgeson-St...7-1-Ratio.html
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
