Old 10-27-2023, 10:57 PM   #1
novaX522
Setting up 72 c10 for towing
Hi, I have a 72 c10 long box. I want to set it up to pull an open trailer with a 70 elCamino on it. Tool box, jack, fuel, etc. Probably 4,000 lbs plus whatever open trailer weighs. I plan to add a Reese hitch, weight distribution setup, new light truck tires, and brake controller. Truck has fresh brakes with discs up front. It has heavy duty rear coils.
My question is there an air bag setup that fits the rear coils?
novaX522 is offline   Reply With Quote
Old 10-28-2023, 09:28 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Setting up 72 c10 for towing
I can't really answer your question but I just wanted to say welcome to the board from a few miles South of you.
I have a pair of air bags that I got with an abandoned project but I think they are lowering bags. I will have to measure them later. I'm thinking you are looking for something that would fit inside the coils?
LockDoc
Leon
Old 10-28-2023, 11:02 AM   #3
novaX522
Thanks! I was wondering if there was an air bag that would fit in the stock spring. That would be an easy way to help the truck while towing. I would be interested in any other solutions.
Old 10-28-2023, 02:13 PM   #4
LockDoc
LockDoc's Avatar
I got to thinking about it and there is really no way to get anything into the center of a rear coil spring because on both ends of the spring the coils are tapered in smaller. (i hope that makes sense)
The bags I have are pretty short.
If I were you I would install a pair of optional overloads that came on the '67 to '72 GM coil spring trucks. Here is a good thread on them.
http://67-72chevytrucks.com/vboard/s...d.php?t=600642
That thread is talking about '60-'66 but the '67-'72 are the same except they only have one leaf for the spring.
I have 2 sets of those. If you are interested I will post a set up on the parts board and give you first shot at them. The only caveat is that you would have to come and pick them up. I won't try to ship them....
LockDoc
Leon
Old 10-28-2023, 02:57 PM   #5
novaX522
I like the helper spring idea. Do you have the springs and the brackets? I would definitely be interested. I know where Montezuma is. I used to drive through there all the time on my way to Eddyville Raceway.
Old 10-28-2023, 03:13 PM   #6
MikeB
MikeB's Avatar
I have to wonder about your brakes when towing >4,000 lbs. I believe there was an optional brake package for a C10 that would give you 2-3/4" wide rear shoes, vs. the usual 2" for 38% more surface area.
I can't find optional front brakes, but there are HD pads available, such as Wagner SX52 severe duty, semi-metallic.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-28-2023, 05:00 PM   #7
LockDoc
LockDoc's Avatar
Yes, I have everything except the bolts, and I may have a few of those for size reference.
LockDoc
Leon
Old 10-28-2023, 07:51 PM   #8
kwmech
Look for some 6 ply tires also
Old 10-28-2023, 10:41 PM   #9
novaX522
Thanks, I’ll put that on my list of things to check this winter.
Old 10-28-2023, 10:45 PM   #10
novaX522
LockDoc
Great! How much do you want for them?
Old 10-28-2023, 11:09 PM   #11
novaX522
Hey Mike, will the 2 3/4” shoes work with the stock drums?
Old 10-28-2023, 11:16 PM   #12
novaX522
I plan to get some light truck tires. Does anyone know what the modern equivalent size tire is for a c10?
I bought it with P275/60-15s on back and P255/60-15s up front. The tires are weather checked, so they need replacing regardless.
I was looking at taller tires like a 265/70-15.
Old 10-28-2023, 11:21 PM   #13
MikeB
MikeB's Avatar
I don't think so. I believe the stock drums have only a 2" wide brake shoe surface. I also read somewhere that the drum ID is 11.2x or 11.3x inches, vs. 11" for the standard C10 brakes.
Mike
Old 10-28-2023, 11:36 PM   #14
MikeB
MikeB's Avatar
There were a few tire size options from the factory. I think my 69 C10 came with a 78-series tire that was a close equivalent to 235-75x15. The overall height of around 29" is about the same as 255-70x15.
A 265-70 is taller than 29". A 255-60 is shorter, as is 275-60, but a lot of guys use those sizes in a front/rear combo.
Mike
Old 10-28-2023, 11:59 PM   #15
novaX522
Thanks Mike! Good info
Old 10-29-2023, 12:41 AM   #16
Richard
Came across this old thread. https://www.67-72chevytrucks.com/vbo...d.php?t=425850
Richard
Old 10-29-2023, 10:23 AM   #17
MikeB
MikeB's Avatar
This is kind of a crude way to do it, but back in the day, I clamped springs like these around the shocks.
Obviously you want just a little preload on the springs with the shocks extended so they don't rattle.
Mike
Old 10-29-2023, 10:45 AM   #18
LockDoc
LockDoc's Avatar
I will take some pictures of them this morning and post them on the parts board. I will post that you have first dibbs on them. I will post a link to the for sale thread here.
LockDoc
Leon
Old 10-29-2023, 11:27 AM   #19
novaX522
Thanks!
Old 10-29-2023, 11:54 AM   #20
LockDoc
LockDoc's Avatar
Posted up the for sale thread located here....
http://67-72chevytrucks.com/vboard/s...d.php?t=848325
LockDoc
Leon
Old 10-29-2023, 12:12 PM   #21
novaX522
Originally Posted by Richard View Post
That’s a great thread. Found part numbers for airbags that fit in coils. Thanks!
Old 10-29-2023, 01:11 PM   #22
Getter-Done
Getter-Done's Avatar
I always like the helper springs.
Also have you thought about running air shocks?
Link for air shocks: https://www.carparts.com/details/Che...2/TSMA727.html
84 Chevy K-20
Old 10-29-2023, 02:30 PM   #23
Richard
Not a fan of air shocks or helper springs on the shocks myself. While many have used them, the shock mounts on any vehicle are not designed to carry loads.
Richard
Old 10-29-2023, 03:08 PM   #24
Steeveedee
Who Changed This?
Steeveedee's Avatar
Not Mike, but...the larger shoes will also require different backing plates.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-29-2023, 04:49 PM   #25
Wikid61
Wikid61's Avatar
https://nolimit.net/store/Dropped-Sh...unts-p26244502 The will move the shocks closer to the wheel/tires.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
