Old 01-10-2004, 03:41 PM   #1
72c5
72c5's Avatar
Single Wall vs Double Wall tops
Hi,
I'm guessing Chevy made the Double wall Blazer top for insulating?
I would assume the are interchangable?
Which is more plentiful, which is more popular?
Do the hatches interchange?
Do they look the same?
Just wondering.........
The idea of using colored (white or black) bedliner seems like a pretty reasonable way to quickly refinish the top.
Gordon
72c5 is offline   Reply With Quote
Old 01-10-2004, 03:52 PM   #2
LeftCoast32
Custom Builder
LeftCoast32's Avatar
It would seem that alot of the Blazers here in California that had A/C had the double wall tops. Now I have also had several Blazers without A/C that had double wall tops but I could usually trace them to states that were either back East or North. No real way to tell what came with what.
Each of the 2 tops are pretty much the same from the outside. The double wall tops have an interior shell added that makes it quite heavy.
Both top use the same rear hatch.
Any Blazer or Jimmy out there has both the threaded inserts (single wall top) and the holes (double wall tops) so they can go either way.
The single wall tops bolt down while the double wall tops bolt up.
I have seen several tops that were done with the bedliner and it is tough and looks good so long as it is done professionally. Keeping it thin seems to be the key to good looks. Just dont let them lay it on like they do for the bed of the trucks. About 1/4" thick for the bed of a truck and 1/16" for the top looks good.
LeftCoast32 is offline   Reply With Quote
Old 01-10-2004, 08:12 PM   #3
Steven B
Steven B's Avatar
Also the single wall tops have the interior lights. The tops also use different hole locations to bolt them down.
Steven B is offline   Reply With Quote
