Old 10-30-2023, 03:09 PM   #1
MikeB
MikeB's Avatar
OER 551448 Coolant Recovery Tank
I'm finishing the installation of an OER 551448 coolant recovery tank in my 69 C10. The tank is made for for 75-79 Nova and other similar GM cars, and it's what a few guys on this forum recommended. The main issue is supporting the bottom of the tank. I ended up using an "L" bracket bolted to the radiator support, with some weatherstripping glued to the top leg.
Had to remove the battery box to get the tank in place. Now I have to remove the radiator to install three body bolts that secure the battery box to the rad support. They were hard to remove, but impossible to install without removing the rad.
Bought some hi-temp 3/8" silicon tubing with 9/16" OD, which looks like it's going to work great. Hope it's OK with antifreeze.
Here's a "work in progress" photo, along with one of the bracket underneath the tank. The tank cap is Dorman 82590.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-31-2023, 12:00 AM   #2
PbFut
Re: OER 551448 Coolant Recovery Tank
I found oer 493072 fit very well down in the void next to the primary battery box. It is not easily seen and cycles perfectly. It will take a few heat cycles to clear all the air. I am really pleased with function. Unless you look for it, the appearance of the area is pretty much factory looking. I like using a clear tube from the radiator neck to the bottle to monitor no air is in the system. I am now confident enough of the function that a swap to black tubing will finish off to a more factory appearance.
PbFut is offline   Reply With Quote
Old 10-31-2023, 11:45 AM   #3
MikeB
MikeB's Avatar
Originally Posted by PbFut View Post
I found oer 493072 fit very well down in the void next to the primary battery box. I like using a clear tube from the radiator neck to the bottle to monitor no air is in the system. I am now confident enough of the function that a swap to black tubing will finish off to a more factory appearance.
Got any photos of the tank installation?
Yeah, I like the clear tube too, including the silicon's flexibility. As for factory appearance, my truck's engine compartment is way past that!
Mike
Old 11-01-2023, 02:00 PM   #4
PbFut
Here you go
I am certainly not stock as well.
Old 11-01-2023, 02:45 PM   #5
MikeB
MikeB's Avatar
Well, you did say you wanted a factory appearance.
Mike
Old 11-02-2023, 05:36 PM   #6
old51sedan
old51sedan's Avatar
I bought coolant tank that was suppose to fit in front of the radiator support, but because of the fact I had installed vintage air it was too tight. I had had this for quite some time so could not return it so decided to install on the firewall. It's not original, but easy to get too.
old51sedan is offline   Reply With Quote
Old 11-03-2023, 02:52 PM   #7
MikeB
MikeB's Avatar
That's a clean installation.
Finally got mine all wrapped up and completely filled the radiator. Fired up the engine and drove around for 15-20 minutes, but engine temp wouldn't get past 160, even when the truck sat idling for 10 minutes. So there was no expansion into the tank. Guess I'll have to try it again in a few days when we are supposed to see mid-80 degree temperatures.
Mike
Old 11-04-2023, 04:12 PM   #8
mongo4298
I used the Dorman 603-001. It was a good fit in front of the radiator. I also used clear tubing.
mongo4298 is offline   Reply With Quote
Old 11-07-2023, 02:04 AM   #9
PowerdbyChevy79
PowerdbyChevy79's Avatar
I like this.. this looks really good.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 11-11-2023, 05:43 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
Here's my Nova puke tank. Mounted, at the time, in my '68 C/10 Stepside w/292. Since the 292 L6 never gets hot enough to need it, I shifted the tank to my other truck, a 350-equipped '71 GMC K/1500 Jimmy.
