Old 01-10-2004, 04:30 PM   #1
71Seth
71Seth's Avatar
why is my 97 1500 slow to engauge 4hi or lo sometimes???
As i said it slow sometimes. seems like i have to bump the throtle or go into revrese. Usely only the first or second time when i'm out playing does it do this. after that it seems to be faily quick. I drove a 04 the other day and as soon as i pulled it in ot 4 lo it was locked in. Is there some linkage adjustments i can make? Or is it eletrical?
Thanks in adv Seth
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 01-11-2004, 01:49 AM   #2
IoWnZa
Big Block Blazer
My Mom's 97' K1500 Cheyenne she had did the same thing, sometimes it would lag before going into either 4 Hi or 4 Low.
The Yukon she has now is quick as **** going in either way, 4 Hi, 4 Low or anything.
/IoWnZa
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 01-11-2004, 06:27 PM   #3
playtoy1
check your actuator on the front axle they are electrical devices when they are cold they are slower after you engage it a couple of times it is warmed up
playtoy1 is offline   Reply With Quote
Old 01-12-2004, 07:00 PM   #4
71Seth
71Seth's Avatar
playtoy1 that sounds like that is my problem. is there a way to get them to work faster?
97 ext cab 4x4
04 pontiac grand am
Old 01-12-2004, 07:57 PM   #5
toddol1971
I swear there was somebody making a conversion of some sort to do away with that. I drive a 71 so im to familiar with all that fancy stuff. My brother in law had to replace his though cause it was working erraticly
All my trucks are gone now. I'll gladly take a free one
toddol1971 is offline   Reply With Quote
Old 01-12-2004, 10:57 PM   #6
playtoy1
yeh there is a way to make them faster just buy a new one
there is a kit to change it to a cable operate system i think it is called posi loc not sure though i heard there over 100.00 for the kit new actuator is 90.00
