Old 11-01-2023, 07:50 PM   #1
damnyankee36
damnyankee36's Avatar
1968 Dash Harness Question
I discovered something odd on a 68. The fuse box has the main harness coming out of the left side. The American Autowire harness I bought, (#33915), has the harness coming out the top.
I thought I got the wrong one but it specifically says it's for a 67-68. What's weird is that AAW's 69-72 harness, (#30100), shows the harness coming out the side like the 68 I have. The fuse layout is the same but it's upside down.
Is it possible that I have a late build and they started using the 69 harnesses in 68? I suppose it's possible that the harness was changed out but I have my doubts. It looks very aged and original.
How can I tell what the build date is without a build sheet?
EDIT:
Been doing some research. The rear end has E118 casting date. I'm gonna guess that's May 11, 1968. Fairly late in the model year.
The transmission is a TH400 with these #'s on the tag: 546 at the top right. At the bottom: CT-68-77380. The 546 is the Julian date, which didn't make sense until I saw a reference stating the date codes started January the year before. So that would make a Julian date of 181 or June 29, 1968. Close to the rear end cast date.
damnyankee36 is offline   Reply With Quote
Old 11-02-2023, 09:54 AM   #2
HO455
Post Whore
HO455's Avatar
Re: 1968 Dash Harness Question
Another possibility is that as part of the ramp up to the new model year trucks they tested the installation of the style new harnesses with your truck.
Or there was a warranty issue with the original harness and the dealer replaced the bad one with a newer one.
These are things you need a time machine to know for sure.
RIP Bob Parks.
Old 11-02-2023, 01:11 PM   #3
68 C10 Driver
Damnyankee36, here is a look at the fuse block in my 68 C10. I will admit this is a new harness/fuse block, but it is identical to the one I removed. The view is as if you were looking up from the floor. I know you will probably ask, that rod connecting to the clutch pedal is the actuator rod for the hydraulic clutch master cylinder. I have noticed when looking at various 68 C10s, that the orientation of the fuse block varies. Some fuse blocks are horizontal, others are vertical. I do not know why that is unless it was how one assembly plant did it versus another. Mine was mounted horizontally from the factory with the original harness, so that is how I installed the new one.
68 C10 Driver is offline   Reply With Quote
Old 11-02-2023, 01:19 PM   #4
damnyankee36
Thanks Driver. Do you have any idea what the build date is? Or even if it's an early or late build?
Old 11-02-2023, 01:21 PM   #5
damnyankee36
Would anybody else be able to look at their fuse box and tell me if the main branch comes out of the top or left side of the box?
Old 11-02-2023, 01:21 PM   #6
68 C10 Driver
Mine was Mar 1968. I will have to go look at the plate for the exact date, but I do know it was Mar.
Old 11-02-2023, 01:23 PM   #7
damnyankee36
That's close enough. Thanks!
Old 11-02-2023, 03:46 PM   #8
pjmoreland
pjmoreland's Avatar
My '68 was built in May and in Fremont, CA. The fuse panel is horizontal with the wire bundle exiting on the long side (top).
pjmoreland is offline   Reply With Quote
Old 11-03-2023, 06:20 PM   #9
HoneyBeeMan68
mine comes out the top, and is the original one and was made in St. Louis.
HoneyBeeMan68 is offline   Reply With Quote
Old 11-03-2023, 09:42 PM   #10
ZEKE68
ZEKE68's Avatar
My 1968 was built in Fremont CA, in October 1967, and the harness comes out of the top of the fuse box.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 11-14-2023, 06:17 PM   #11
Jason Banks
Jason Banks's Avatar
I'm late but thought I'd update.
I have 2 1968... One of them an October 1967 Fremont truck like ZEKE68 and it comes out the top.
The other is a later Janesville build and it also comes out the top.
Jason Banks is offline   Reply With Quote
