11-12-2023, 08:42 PM | #1 |
Should have expected it
Switching back to AC Delco R44T plugs. I guess I shouldn't be surprised they are made in China.
Last edited by LockDoc; 11-12-2023 at 09:23 PM. Reason: Removed Political statement. |
11-12-2023, 09:20 PM | #2 |
Re: Should have expected it
I am thinking of putting in Autolite 24 spark plugs.
11-12-2023, 11:05 PM | #3 |
The last few GM part I bought were all made in China.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-12-2023, 11:38 PM | #4 |
They used to be made in the Mt Morris, Michigan, but NAFTA and numerous other “Trade Treaties” changed all that.
11-13-2023, 12:46 AM | #5 |
It is what it is.
The new AC DELCO Master Brake Cylinder I recently bought is made in China. Crossing my fingers on quality and function. Nothing new that we haven’t discussed here before on this subject. Sadly, products across the spectrum are sold, distributed and supported here in the USA, but manufactured overseas.
Sam 1972 C10 LWB 2020 Z71 Tahoe |
11-13-2023, 02:01 AM | #6 |
I use Denso spark plugs which I believe are made in Southfield, Michigan.
11-13-2023, 09:16 AM | #7 |
I have bought scores of good USA made NOS AC spark plugs from EBAY. There seems to be a good supply of them still out there, and if stored properly will last centuries.
Here are some good R44T plugs: 11 for around $50: https://www.ebay.com/itm/14542684403...Bk9SR5TFjo35Yg AND.. https://www.ebay.com/itm/11568052006...Bk9SR5jFjo35Yg
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-13-2023, 12:51 PM | #8 |
11-13-2023, 01:36 PM | #9 |
AC Delco parts have been made in China for the past 8-10 years....maybe longer
11-13-2023, 03:01 PM | #10 |
I've been real happy with 'hecho in japon' NGK YR5 in my tired, Delco-fouling 350. I haven't had to pull a plug since I installed them.
11-13-2023, 03:02 PM | #11 |
When they first left Michigan, they went to Mexico. I wasn't satisfied with the quality of the Mexican build, so I dropped the AC brand, as it had lost its meaning. I guess Corporate found they could get the plugs made better and cheaper in China. At least cheaper.
11-13-2023, 03:12 PM | #12 |
I always call NGK the "No Good Kind".
In my R/C stadium truck, I use NGK plugs and it seems to like them. I run Champions in my Kohler small engines in my vintage Cub Cadets, and NOS green ribbed AC plugs in my older GM vehicles.
11-13-2023, 03:29 PM | #13 |
In the not to distant future Barra will be identified as the singular individual responsible for the demise of GM.
71 C-20 07 Magnum RT AWD |
11-13-2023, 04:41 PM | #14 | |
Junior Member
I'm running AC Delco's I ordered through Summit. They've been good so far, but haven't put many miles on them.
awbanks 1971 C20 Longhorn |
11-14-2023, 11:02 AM | #15 |
@1970cstblazer: Thanks for the tip, I bought some of these NOS AC plugs.
11-15-2023, 04:45 PM | #16 |
11-15-2023, 05:09 PM | #17 |
I'll have to look it up, or check the rig, and get back to you.
OK: W16EPR-U Looks like I'm running rich, too.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-15-2023 at 06:53 PM. |
11-15-2023, 07:57 PM | #18 |
Got the aftermarket AC R44Ts installed. No blood spilled which is unusual for me. Factory air and the back 2 are the knuckle busters. Fire it up tomorrow. Raining.
11-15-2023, 09:50 PM | #19 |
Cool.
11-15-2023, 09:53 PM | #20 |
I'm using the AC R44T in my 292, because I have the later head with the tapered seats.
To me, that Denso W16EPR-U in your picture looks way to long, but best I could find, it does cross reference to the AC R44XL which is the correct plug for the inline six with gasketed seat.
'67 GMC 2500, 292, 4spd, AC |
11-16-2023, 12:02 AM | #21 | |
Also ran Champion RN 11 or 12YC but I can't really remember. I have a set of US made AC 45 plugs, but my mechanic says I don't need to go a range hotter on my 350 in the Jimmy.
11-16-2023, 01:54 AM | #22 |
68 orange: Thanks for the info on those plugs!
11-16-2023, 05:00 PM | #23 |
11-16-2023, 10:03 PM | #24 |
11-17-2023, 06:01 PM | #25 |
[QUOTE/[I have a set of US made AC 45 plugs, but my mechanic says I don't need to go a range hotter on my 350 in the Jimmy.[/QUOTE]
Unless you have HEI. Then you will want the R45Ts.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
