Old 01-10-2004, 06:55 PM   #1
gotmud
gotmud's Avatar
Question Before I Start Cutting...
Thought I would ask before I put it to the grinder. Has anyone put a Edelbrock 1405 on a 68 307 before? The throttle is connected to the old carb via a round piece of solid metal. On the 1405 it fits perfect in a lower hole but it has to go in the upper hole because when you press the gas it pulls the throdle instead of pushing it.
I think I can get it to fit using my grinder on the throttle metal bar but hate to grind anything that I may want to put back stock later.
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-10-2004, 08:45 PM   #2
86SILVERADO
86SILVERADO's Avatar
Glenn,
When you grind off the fitting for the cable on top of the throttle tang you will find that the rod connector end fits perfectly in there. I just did this to an old Q-jet to put in my 67.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 01-11-2004, 01:33 AM   #3
Hooter
My other Love
Hooter's Avatar
Thats what I did when I put an AFB on my 454, but I ended up going back to the Quadrajet, because the motor ran better with it
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
