Old 11-14-2023, 07:15 PM   #1
mvfd70
mvfd70's Avatar
Spark advance issue
Been a long time since I've been on here. Glad to see this site is still up and running. Anyways, here is my issue. 1994 Chevy K1500 with a 5.7 TBI. Using TunerPro RT this is what I see when I'm under a slight load in overdrive. The truck runs terrible and has no power to go up a small incline without downshifting to a lower gear. Sometimes even drops to 2nd gear. The spark advance appears normal until the engine starts to lug a little bit then it jumps to this 23000 number. If I mash the gas and make it shift gears so the RPMs increase the advance will drop back to a normal range.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
