Old 11-17-2023, 09:30 PM   #1
chevy72blu
chevy72blu's Avatar
Engine running rough below 3k RPM. Fine above it. ???
I have a stock '98 LS1 in my truck which has been there for years. It sat for a while. t
There is a stumble and hesitation at low RPM that seems to go away around 2500-3k RPM. First thought was bad gas, but I pumped out what I could and I've ran a few gallons of fresh 91 octane. Maybe helped a little? Cleaned MAF and TB. No change.
It also takes several cranks to fire, whereas it used to fire on the first crank.
I would think any issue fuel related would be worse at high RPM.
Ignition issues? I was thinking maybe coils? No codes. O2 sensors?
The truck is down probably 100HP, but otherwise runs and drives just fine.
Thank you for your thoughts!
Edit: Pulled one plug, it looked fine.
OBD2 scanner shows good output from the O2 sensors (rear deleted).
Sitting in it at idle for a long period, it is definitely idling rougher than it ever did before. Stable, but bumpy, like a cam with a lot of duration (it is stock). Took it on another drive and while it was hesitating I floored it - bogged and lost all power until it recovered from that (engine did not die).
I feel like this should be fairly obvious but it's been a while since this thing was my hobby.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
