Old 11-23-2023, 12:57 PM   #1
vardenafil
future proofing cooling issues
hi guys. happy turkey day! I have a stock 350 sbc in my a/c truck. it overheats in city traffic but not on the highway. i read that on the forums that would be a fan flow issue not radiator issue. i replaced the thermostat w/ a high flow 180 stat last week. i have a severe duty clutch fan coming in sometime after the holidays. i dont know if that will solve the issue though since the current clutch fan looks brand new. hopefully that will take care of me for awhile. my truck is currently the stock 170 horsepower truck. eventually i want to buy a complete torquer kit from summit or the likes to get it close to 270 horsepower. where i live it gets up to 120 degrees several times a year. we are over 100+ degrees almost half the year. so i need to future proof my cooling needs. I was thinking about replacing the radiator now seeing how the radiator looks stock? would a new 4 core stock radiator suffice? Do i need to go aluminum? or can/should i drop in a longer radiator such as a bbc 454 radiator to help cool?
vardenafil is offline   Reply With Quote
Old 11-23-2023, 01:39 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: future proofing cooling issues
How is your fan shroud? How many blades are the fan?
You might benefit from a new rad, but good to eliminate a few other variables.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-23-2023, 03:20 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Exactly where I would start. Also does the fan fit properly in the shroud? What is the diameter of your fan?
Is your existing fan clutch standard duty or heavy duty? A few pics would help.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-23-2023, 03:35 PM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
Does the fan you have now spin freely, or is there some resistance?
Shroud is always worth a look too, as noted above
Rust_never_sleeps is offline   Reply With Quote
Old 11-23-2023, 03:45 PM   #5
dagnabbitt
dagnabbitt's Avatar
Also: although you say the truck is stock, have you had the truck for long? Would you be able to say it has been worked on by someone who knows what they are doing, or did the last guy seem clueless.
I once had a truck that the previous owner said just needed a new rad for sure: he knew this because he had eliminated all of the other variables... he said it actually ran hotter after he installed a brand new fan. I noticed that he had put it on backwards, I flipped it around and it was fine.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-24-2023, 07:42 PM   #6
vardenafil
The fan shroud looks decent. There is a stock I assume 7 blade fan attached. I’m not too sure what service level the clutch fan is. It looks brand new. No dirt or anything on the fan still shinny. I’ve had the truck a year now. But who knows what the previous owner did
Old 11-24-2023, 07:53 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
https://www.haydenauto.com/en/produc...-types/thermal
Standard duty: Identified by a smooth steel faceplate & thermal spring assembly on the front side.
Heavy duty: Identified by finned aluminum faceplate and thermal spring on the front. This is a Hayden #2747 which is what I have on my K20.
Severe duty: Land and groove design with up to 72 sq. in. of working area.
Larger working surface provides cooler running and longer life expectancy.
Thicker body and deep finned faceplate dissipates more heat.
- Mike -
RIP El Jay
Old 11-24-2023, 09:58 PM   #8
HO455
Post Whore
HO455's Avatar
How the fan sits inside the shroud is also important. Too far inside or outside of the shroud is bad for air flow through the radiator. See arrow in picture for how the fan should be located and notice how close the fan blade is to shroud.
Have you taken a look inside the radiator? You may have to drain some coolant to get a good look. Do you see build up on the tubes?
RIP Bob Parks.
Old 11-25-2023, 02:49 PM   #9
Myself
I'm sure some folks will hate this answer BUT........twice now I've done the cheapo 3 row aluminum overseas radiators from Ebay. The ones that come with an aluminum shroud and twin electric fans. Wire up 3 ice cube relays in the "LS" high and low style setup and a Volvo double temp switch (needs a metric adapter to thread into the intake or water pump) and don't ever worry about overheating again.
Myself is offline   Reply With Quote
Old 11-26-2023, 11:47 AM   #10
Sheepdip
Sheepdip's Avatar
Not Me!
I like originality for the most part but I'm also all about trouble free function.
When Otis needed a radiator I installed a Champion system to cool up to 1000 hp. With the hot valley summers running A/C, towing trailers, high amperage alternator, etc. I have plenty of cooling in 100+ degree heat, stop n go city traffic, windows up and ice cold A/C blowing in my face.
I currently run 3 Champion Systems all with A/C, all with thermostatic controlled electric fans, one has been in for over 20 years and never a hint of a problem.
Bottom line it's your truck so do what satisfies you.
Sheepdip is online now   Reply With Quote
Old 11-26-2023, 01:51 PM   #11
PbFut
I have the champion setup. Works very good in the so cal inland heat. Hill and many days over 100 with ac. But the duel fans are hard on the electrical system and requires some modifications if you want to correctly wire to the main splice so the stock battery guage registers correctly without pinning. Simply wiring to the fuse link block will work but render the battery guage nearly useless.
I also added a remote oil filter with 2quart filter to up capacity and a large oil cooler. That helps a lot. Having to do over, I would try to get the oem shroud and fan to work rather than the electric fans. One last note on the champion fans. Do not use their connectors. They do not stay connected tightly and will kill the fan quickly with a low amperage condition in the high heat of summer. I killed two fans thinking I messed up t
Plugging in only to have the second one fail few weeks later. I removed connectors and soldered. No issues since. I also added an additional relay that triggers when the ac compressor triggers and coolant is below trigger temp. If you don't have ac and you don't care about battery guage working correctly, wiring the fans is simple. But if you want everything correct, the wiring takes some thought, planning and at least a full day to execute.
PbFut is offline   Reply With Quote
Old 11-26-2023, 05:33 PM   #12
LS short box
Not a SBC but on my LS swaps I run the biggest alum radiator I can fit. On my 68 it was a Afco generic LS swap radiator. 16" Spal electric fan which on some of my LS swaps ran off a switch in the radiator or by the ECM. You can get the Afco rad configured for a SBC also. IIRC I bought from Speedway Motors.
LS short box is offline   Reply With Quote
Old 11-27-2023, 08:43 AM   #13
don t. - 72gmc
As others have said, do the easy stuff 1st.
Thermostat in the proper direction.
Fan, shroud, fan clutch working as it should.
Maybe R&R the lower rad hose if old and soft.
Im not a fan of internet type purchases. I took my old rad out to a local radiator shop. Had him recore it to factory specs. I then knew, it would fit w/no monkeying around. This solved my overheat issue.
HTH...Don.
don t. - 72gmc is offline   Reply With Quote
Old 11-27-2023, 11:36 AM   #14
Sheepdip
Sheepdip's Avatar
HTH...Don.
All valid points to check off the list.
Here in Kalifornia an acid bath for a radiator does not exist, and has not for quite some time, so a good rebuild/re-core on a original brass radiator no longer exist.
Old 11-27-2023, 02:52 PM   #15
54blackhornet
54blackhornet's Avatar
For anyone who is interested there is an old style radiator shop located in Walla Walla Washington. Grieners is the name. Been in operation since the 30/40’s. I have had numerous radiators rebuilt by them. Excellent work every time..
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-27-2023, 03:24 PM   #16
Rust_never_sleeps
Pankey's in Hayward, CA has been doing great work for about 80 years. 510-581-6804
Old 11-27-2023, 04:33 PM   #17
don t. - 72gmc
I'll give a shout out to Tim at Revcore Radiators in Woodstock, Ill-noise. I've had many items repaired by Tim well over 30 years.
Old 11-29-2023, 09:27 PM   #18
vardenafil
https://ibb.co/DKQ6dQh
https://ibb.co/R9wftVz
https://ibb.co/m8zDjbF
https://ibb.co/DKnRMZn
Sorry it took so long for me to respond. I didn’t mean to ask for advice and then abandon my post. I got hit with pneumonia and covid and haven’t been up to much the last 10 days or so.still not at 100 percent but doing better.
From what I can tell the fan clutch looks brand new as well as the fan shroud. The fan shroud is fit properly no gaps etc. the fan clutch appears to be a hayde 2747 which would be the correct medium duty fan clutch. I don’t know if the severe duty clutch would be worth the investment. There is no play or wobble in the fan clutch. If I spin the fan by hand the fan immediately stops. So I think the fan clutch is good? The thermostat is installed correctly going the right way. The upper radiator hose does not seem to be a molded hose it looks like it is a straight hose bent to fit but it is not kinked by any means. The lower hose feels solid. The only thing that might be helpful when I overheated last time the temp gauge was about 220. That seems kinda low? Thanks in advance for any advice
Last edited by vardenafil; 11-29-2023 at 09:52 PM. Reason: Trying to figure out pictures
Old 11-29-2023, 10:00 PM   #19
vardenafil
How do I tell if my fan blades are on backwards?
Old 11-29-2023, 10:49 PM   #20
HO455
Post Whore
HO455's Avatar
Sometimes they have a F or FRT stamped on them to indicate the front of the fan.
Post a photo and maybe one of the folks here can answer that for you.
RIP Bob Parks.
Old 11-30-2023, 12:26 AM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
On the plate that mounts to the fan clutch, the blades are on the radiator side.
~Steven
Simi Valley, CA
Old 11-30-2023, 11:10 AM   #22
vardenafil
here is the pic I could get of the fan blades position relative to the clutch. https://ibb.co/m8zDjbF
Old 11-30-2023, 12:27 PM   #23
72SB
get a 18" 7 blade fan
72SB is offline   Reply With Quote
Old 11-30-2023, 01:07 PM   #24
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x2!
- Mike -
RIP El Jay
Old 11-30-2023, 02:47 PM   #25
vardenafil
The truck already has a seven blade 18 inch fan.
