Truck wont shut off with ignition.
New problem. Arrived at the store today and went to shut the truck off. Turned the key, and it was still running. Used the manual choke to kill the engine, and then disconnected battery cables. When I came back out I was fully expecting it to fix itself. LOL Hooked the battery back up, started the truck and went home.
Got home, same thing. Truck wouldn't shut off with the key. The ignition switch is new. Replaced it this spring, sourced from LMC. Any Ideas? I appreciate the help. Im not great at wiring.
"Sucks to be you" Suxtobu65 ![]() |
![]() Join Date: Dec 2009
Re: Truck wont shut off with ignition.
Great thinking to cut it off get your shopping done and get back home.
Several have issues with New switches. Here is a Thread about the switch. Link: https://67-72chevytrucks.com/vboard/...n+switch+issue ![]() ![]() ![]()
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
