Old 01-10-2004, 10:44 PM   #1
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
Question Interchangable clutch parts...?
OK. Who knows what clutch parts are interchangable between 60-66, 67-72, and 73-87?? Are they all interchangable including the parts inside of the cab? I don't know very much about this subject. I have a 65 Chevy on a 77' frame. Can I use 67-87 clutch parts? Or will they not fit well. I am just trying to find information.... I have a 4-speed tranny but no clutch parts at all. There is no clutch inside the cab but it has a manual transmission steering column. Please help this confused soul! Thanks!
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Old 01-11-2004, 01:13 PM   #2
Yachtcare
I'm no expert by far, but I think your biggest concern may be what goes between the clutch pedal and the clutch itself. Will you be using a hydraulic, or a mechanical setup? That should be determined by the type of bellhousing you have. Which 4 speed do you have? I think, but am not certain, that the 4 speeds use a 11" clutch disc, as opposed to 10" or 11" on the 3 speeds. If you take the info regarding what year the transmission came from, and what type of bellhousing you have, your local parts counter guy should be able to fix you up with the clutch, while you head to the salvage yard for pedal and linkage.
1961 Chevy Apache 10 SWB fleet, 1970 GMC 1500 SWB fleet(getting 6.2L Detroit turbo Diesel), 1994 Chevy 3500 Crew Cab Dually 4X4 6.5L turbo Diesel. 1990 Chevy class "C" RV on G van chassis. Pics at www.picturetrail.com/yachtcare
Yachtcare is offline   Reply With Quote
