Location: 3,018 feet above the SoCal/Mojave Desert region.
Turn signal switch doesn't fit.
OK, so the truck is a '72 with tilt column. But it has the black hazard button with the shift indicator bulb. But I have no turn signals. So I purchased a new turn signal switch that says has the correct red button hazard for tilt column. I was confused about the red hazard button. The new switch with "correct" red hazard doesn't fit though. When I put the old switch back in with the black round hazard, it fits like a charm.
Maybe the steering column was swapped? Even the hole for the hazard switch seems big enough for the round black hazard button. Any help would be appreciated. Thanks. |
#2 | |
![]() Join Date: Apr 2010
Re: Turn signal switch doesn't fit.
Mr. Cheyenne
![]() Join Date: Jun 2020
I went though this too. I bought a tilt column from the forums and the cable for the switch was causing a ground short. It was also has a black pull for the hazards and I changed it to the red one that didn't need a half-moon adapter.
The only way to get the red one in is to remove the bezel, which is a pain if you don't have the puller (Kent Moore j-22708). No one hardly has one. Dissembling a tilt column I could be wrong but I bet you need to remove the cover to get your new "red" switch in.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#4 | |
Mr. Cheyenne
Do you have to use the red one? No you don't. At some point you'll care after driving enough times at night! You can get the Black or Red with the light bulb, which is the one that is designed for a tilt column. I would think the one you see on Amazon is for the Non-Tilt Column version with the light fiber line to the cluster dash lights.
But if you get the Red one again, I am nearly 100% sure you need to remove the bezel - be sure to look at that thread I put in my previous reply. I think the reason is: you can't remove the red pull, like you can the black one. It is all up to you which direction to go but the Red on can be installed (but it can be a PITA to get the Bezel off).
![]() Join Date: Feb 2002
The Red Button is for '68. Later models use the 2 piece black button.
This is the one I use, same as the tilt wiring harness but without the light assembly which just screws onto the bottom side of the non tilt harness. I have plenty of light assemblies if you need one.
https://www.ebay.com/itm/200918678705 |
#8 | |
#10 | |
It's easier to install the black button version, because you can unscrew the knob, and the switch assembly just drops into the column-- then you screw the pull knob back on. The red ones seem to fight their way in. Probably why they were superceded during the production run. Nowdays, Manufacturers for ''Vintage Cars'' think of themselves as toymakers. With about the same degree of quality assurance.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-04-2023 at 05:37 AM. |
![]() Join Date: Nov 2013
Just ran across this last week.
I bought one from Classic parts that was supposed to be for a tilt column with the detachable hazard knob. It did not have the provision for the indicator bulb. The only one I could find had the red non-removable hazard knob. I ended up making a puller using the dimensions that someone posted on here, to remove the outer ring on column in order to get it installed. Once installed it works perfectly.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
#12 | |
Mr. Cheyenne
Two threads worth reviewing: Hazard Switch Tilt wheel Hazard Switch
#13 | |
#14 |
Seems like the link that 70shortfleet shared may be the way to go with the back hazard button and just attach the shift light to that one since all the assemblies have the mounting holes for the light. What I noticed, unless pictures defy me, the columns with the red hazard button is rectangular shape and the columns with the black hazard button is round. Am I seeing this wrong? I'm going with the black button since the install will be easier.
#15 |
That is odd, my hazard switch is silver and is original to the truck.
#16 |
#17 |
No, I don't think they did at times. I also have a MG and it appears in some instances the assembly line would use parts from the previous model year (even if it was year specific) until they exhausted that part inventory.
#18 | |
I bought my '68 C/10 Stepside in 1973. I have no doubt the Red knob was original to my truck.
#19 |
You just have to forget about today's technology, bar coded, and JIT manufacturing...
In those years...they built them and sold them as fast as possible....any combination is not only probable, but also very possible... If it work's like it's supposed to....I'm all in .....mine is red....I'm moving ahead....
#20 | |
![]() ![]() Join Date: Jan 2005
#21 | |
#22 | |
I drew it up by your 2D dimensions and created a solid model....used some scrap aluminum that was slated for the metal recycler...a couple of hours from start to finish... ![]() I was expecting the collar to be fairly snug but it came off with the greatest of ease. Once it was off the new switch went in easily, especially feeding the wiring harness in....
#23 | |
I looked closely at the one I bought from Classic Parts....the assembly was entirely different on it because I was looking to see if the bulb would mount to it easily...it would not...most all the others I looked at had the red non-removable HZ knob?
#24 |
| Bookmarks |
