12-05-2023, 08:54 AM | #1 |
Mirror Screw holes
The mirrors on the 63 are loose.
The screw holes are wallered out. Not sure if they will hold, but I ordered some of those plastic license plate nuts and screws. At some point I will replace the mirrors, but this might keep me from spending that money until after I get it running well. Waiting on Carburetor throttle shaft bushings to finish rebuilding it. I plan on starting replacing the wiring harness Today.
Take Care, Dave |
12-05-2023, 11:28 AM | #2 |
Re: Mirror Screw holes
Is the weldnut thick enough to do a heli-coil?
I used nutserts to install a passenger side mirror, perhaps you could drill it out and use a nutsert, however you'd likely have to remove all of the old weldnut as a nutsert needs relatively thin metal to attach. A stop-gap measure can be slipping some wire in between the threads to take up some of the thread gap.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-07-2023, 04:45 PM | #3 |
Can you get some longer bolts and add nuts on the other side of the wallered out nuts
12-07-2023, 07:09 PM | #4 |
LOL, well that was a dumb idea.
I did one and it held, but can tell that will not last. I like the nutsert idea. Looks like they are just holes and no threads. Maybe the backing nuts fell off or something. Yeah, I was thinking just a bolt and nut.
Take Care, Dave |
12-07-2023, 07:11 PM | #5 |
Is it on the drivers side or passenger side?
12-07-2023, 07:48 PM | #6 |
Both sides have 1 or 2 loose.
Take Care, Dave |
12-14-2023, 04:33 PM | #7 |
Also used nutserts for my new doors, you can use a bolt the size of the nutsert and a size up nut to crimp them down.
They seem to be holding pretty good so far.
1964 C10 Resto-mod 5.3L - L59 |
12-14-2023, 08:55 PM | #8 |
I mounted mine with rivnuts
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 Last edited by karlbenz; 12-14-2023 at 09:19 PM. |
