Old 12-12-2023, 02:02 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Seat Belts - OER vs Motor City K5
Can someone explain the differences between the seat belts that OER sells vs Motor City
Both appear to be period correct looking ? The blue button on the OER set doesn't appear to have the GM logo but that can be switched out fairly easily.
Trying to justify the cost delta - OER $430 vs Motor City $650
thanks
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 12-12-2023, 06:38 PM   #2
Richard
Re: Seat Belts - OER vs Motor City K5
thanks
The OER belts all use the same buckle while the Motor City rear belts have a different style buckle which I believe is oem accurate.
Richard
Old 12-13-2023, 02:51 AM   #3
Bob B.
Any reason the Motor City belts would not work in a truck instread of a Blazer/Jimmy?
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-13-2023, 04:22 AM   #4
Richard
If you have bucket seats I see no reason they would not work. I did not see a non-retractable center belt for a bench with the same style buckle as the front seats on the Motor City website.
A Blazer owner should correct me if wrong about rear seat in a Blazer using the different style buckles. Believe Mark at K5 is offering what is correct for the Blazer.
Richard
Old 12-15-2023, 06:42 PM   #5
6600DURAMAX
The buckle in the OER picture look pretty darn close to factory
Does anyone have OER or Motor City Belts in their vehicle ?
Old 12-18-2023, 06:03 PM   #6
6600DURAMAX
No one has the OER or Motorcity seat belts ...? huh
