12-12-2023, 03:54 PM | #1 |
Junior Member
Grease pen markings on firewall behind distributor (8cyl)
I remember seeing markings on the firewall above trans hump.
I'm curious if anyone has info on what they represented. For instance GM514 which would be the paint code. Or, would the markings represent production info ? I looked in the assembly manual and I don't see anything on the topic |
12-12-2023, 06:47 PM | #2 |
Re: Grease pen markings on firewall behind distributor (8cyl)
For your reading enjoyment:
http://67-72chevytrucks.com/vboard/s...light=sequence http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...light=graffiti http://67-72chevytrucks.com/vboard/s...d.php?t=545345 http://67-72chevytrucks.com/vboard/s....php?p=6543084 If you search "grease pencil" there may be more. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-12-2023, 06:49 PM | #3 | |
They were more a local "help a brutha out" and therefore would vary plant to plant, shift to shift and even operator to operator. K
12-14-2023, 07:49 AM | #4 |
Junior Member
Wow that is some great info to speculate on
I ended up swapping cabs and fresh paint so I don't have the the original markings any longer. I guess I can add the tail end of the vin to make it more "original " looking. |
12-14-2023, 10:11 AM | #5 | |
1 - No speculation here; I wrote a few of those notations myself. 2 - None of those are the VIN proper, or the sequential portion of the VIN. Any serialized information would be the build sequence number. Nobody cares about the VIN in the assembly plant (other than to get the VIN tag on the right truck, just like an emissions label, SPID, or Mulroney window label). K
12-14-2023, 10:47 AM | #6 | |
Like one time there was a guy that was installing gas tanks. During some downtime we was using his paint pen to draw a little bumblebee on the fuel tank. It was actually facing the body so it would never be seen again, UNTIL the car needed a repair done while it was still in the factory. The gas tank needed removed and they saw the bumblebee. They were able to trace it back to the guy that was on that job at the time because of the records that were documented. When a certain person was doing that job, we would use our clock numbers. Poor guy got fired over it. They found out he had been doing this for awhile, lol. So out there in the mass of vehicles that were made during my 30 years of working at the assembly plant, my clock number is most likely on several vehicles out there. Along with other grease pen marking I made. My last 5 years I was in the Vehicle Quality Dept, so I used my grease a lot! We used them to circle defects in the paint, or circle little deforms that we would find. It made it easier for the repair person to see what I saw, and it would get fixed before leaving the plant.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 12-14-2023 at 10:54 AM. |
12-14-2023, 10:52 AM | #7 |
Great information
12-14-2023, 02:54 PM | #8 |
In my case I spent two summers building preproduction units down the regular assembly line in the Wentzville plant (I mean, in addition to the other 45 years I've spent launching product).
It was tricky because the front of dash proliferated between gas jobs and diesel, so I was feeding material into two separate lines - and - I had to do it several stations before the vehicle identity was assigned. So I had to count ahead and predict where my special parts were going to hit. Add to that the line was relatively slow (around 36 jobs per hour) and there was a lot of starting and stopping. A lot of times you would be aaaalllmooooost there, and then the line would go down (either a breakdown or for an official break) so you had to sit there a wait for a half hour or shift change or whatever to complete what you were going to do. It was enough to make you crazy trying to keep track of where you were. At any rate - I had a photo of all my special front of dash assemblies lined up on the shop floor, waiting to be fed into the system, and will all my notations, but I think I lost it when I retired. There are going to be some confused folks in the unlikely event somebody wants to restore one of those G vans. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-14-2023 at 03:04 PM. |
12-14-2023, 03:00 PM | #9 |
Keith-
Glad you are on this board to share the insiders view. As with the Pontiac boards, you are an asset to the hobby.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-14-2023, 03:03 PM | #10 |
One other thought I had is that, during these preproduction activities, the bosses usually didn't show up until vehicles were going into trim.
I didn't really appreciate until I had body sheet metal design/responsibility how much magic takes place in the cab shop. There is a lot of dark hours sticking panels together by firelight before the rest of the regular launch team even arrives. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-14-2023 at 09:33 PM. |
12-14-2023, 03:07 PM | #11 | |
K :awshucks:
