Old 12-13-2023, 06:20 PM   #1
howzzzit
howzzzit's Avatar
Cargo lamp wiring plug
Anyone know where I might find a plastic snap on power connector with pigtail for the cargo lamp bulb? Mine only makes contact if wiggled just right.
howzzzit is offline   Reply With Quote
Old 12-13-2023, 08:10 PM   #2
Accelo
Accelo's Avatar
Re: Cargo lamp wiring plug
https://www.summitracing.com/parts/s...dFf1ectRpaOJZg
maybe?
Try Looking under 1969 Camaro backup light? They are the same light.
Accelo is offline   Reply With Quote
Old 12-13-2023, 08:26 PM   #3
howzzzit
howzzzit's Avatar
Thanks Accelo. It's the one with the ears in this old thread. How do I contact the person who posted?
http://67-72chevytrucks.com/vboard/s...d.php?t=800939
Old 12-13-2023, 09:23 PM   #4
chevmn
If it is the one I think you are referring, it has the same plug as a tail light and I ended up getting one from LMC and did some creative work to swap it in. check number 6 in this diagram.
https://www.lmctruck.com/1967-72-che...light-suburban
At any rate, it worked for me. (Assuming you are referring to what I am.
chevmn is offline   Reply With Quote
Old 12-14-2023, 01:26 AM   #5
howzzzit
howzzzit's Avatar
Chevmn that's the connector. Knew I'd see one somewhere. I have my old tail wiring harness tucked away. I'll check it out. Snip snip. Thanks.
Old 12-17-2023, 12:06 PM   #6
Getter-Done
Getter-Done's Avatar
Here is another option.
Link: https://swclassics.com/1969-72-chevy...ng-harness-ea/
The early bird gets the worm,
85 Chevy K-20
Old 12-17-2023, 02:14 PM   #7
howzzzit
howzzzit's Avatar
Originally Posted by Getter-Done View Post
Good find. Thanks.
